Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Trying to replace a bad crank in 1996 kx60
I'm trying to replace the crank in a 1996 kx60, but I can't seem to figure out how to get the magneto? off the bike. Have all of the bolts out of the left side, have the nut off the magneto and have a gear puller on it, but it won't budge. Is there a trick to getting this off? Is there some sort of lock washer or something in there?
The engine is off the bike and on the bench. Once I get that off, I presume that I should be able to tap the casing with a rubber mallet to get it to split.
Appreciate any suggestions.
4 Suggested Answers
DJ_MAX1369
  • 119 Answers
SOURCE: 97 fatboy starter engages but will not stay engaged.
I would check the starter clutch its self first. It is a one way clutch so if you remove the starter and disassemble it to the starter clutch and hold the starter clutch in one hand and use your other hand to turn the starter clutch gear, it should only turn in one direction.
Posted on Mar 31, 2009
bunnydawg
  • 5158 Answers
SOURCE: KX60 2001,losing oil from crank casing and won't start.
it could start without oil..... but the amount of damage you would likely do to it makes it very unwise. if all the oil leaked out there was oil in it when it was started before. if i'm not mistaken that case is aluminum. if you can find someone that does tig welding (i think it's tig for aluminum).... they could probably weld that crack without taking the motor apart..... just a thought.
please take a moment to rate this solution.. thanks
Posted on Apr 16, 2009
  • 116 Answers
SOURCE: Harley hard starting problem
highley doubtful on exaust leak causing problem first make sure your battery is up to the task do a load test if that looks good do a draw test on the starter if not there it starts to get ugly that motor came with a torrington bearing on the sprocketshaft as they wear they develop crankshaft runout not a real big issue till your running straight gears on the camshafts which only tolerates .001 runout you could be binding there
Posted on Dec 30, 2009
Does anyone have an idea as to what is causing this issue?
These cars have a history of bad camshaft sensors. This would be my first suspicion.
Oct 04, 2015 | 1996 Chrysler LHS
Fit kawasaki kx 60 crank
What is the question? Are you trying to put KX60 crank in a KX65? If so, I am pretty sure that won't work without a lot of modifications.
Jul 13, 2014 | 2004 kawasaki KX 65
Battery not charging gx670
The voltage regulator may be bad, will need to unplug magneto and use multi meter and test magneto for voltage output on milliamp scale with the engine cranking, If voltage is present when cranking then the voltage regulator is bad , if no voltage then the pick-up coil and stator will need to be replaced.
Jan 28, 2014 | V-Twin Horizontal OHV Engine with Electric...
1989 Kawasaki KX60 cuts out while riding
Hi, Earle and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Air/fuel mixture screw improperly adjusted.
11. Accelerator pump damaged or not working.
12. Water or dirt in the fuel system, carburetor or filter.
13. Restricted, blocked or kinked fuel line.
14. Fuel tank empty.
15. The gas cap is not venting properly or fuel tank venting system blocked.
16. A failed fuel pump, pressure regulator and or fuel injectors.
17. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
18. Needle and seat stuck closed in the float bowl.
19. Lean angle switch is faulty or needs adjustment.
20. Catastrophic engine failure, perform a compression test.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KX60 stalling
Kawasaki KX60 1995 Won run properly HELP
Kawasaki KX60 Service Manual
OEM Parts for Kawasaki
1991 Kawasaki KX60 Owner Manual
Nov 08, 2017 | kawasaki Motorcycles
Trying to figure or see diagram how to remove and install crank sensor
Check out the autozone.com website and register the car. It doesn't cost anything and will give you access to an online repair manual for the car. The steps for replacing the crank sensor may be available there. Hope this helped and best wishes.
Sep 02, 2009 | 1996 Buick LeSabre
1996 nissan quest. car wont start and just keeps trying to crank. it has a knock sensor code that i pulled out of the dtc. it has no injector pulse and we are trying to figure out if the knock sensor...
Have a bad knock sensor on my 06 villager and no problem driving it daily, most likely you may have a coil problem, fuel pump or MAF sensor problem. Hope this works
Jul 29, 2009 | 1996 Nissan Quest
Poulan Pro 200 Leaf Blower won't start. I have installed a carb kit with no results. The spark plug was wet before the new kit---it continues to be wet. I have tried a replacement spark plug with no...
Ok. Good job on doing what you could, right off! The simplest things are the most overlooked, and the most unforgiving.
So, you know your plug is wet, so you got some fuel flow.
Now let's figure out the plug no-fire problem. (This is under the assumption you haven't beat on this blower with a sledge-hammer at one point. The whole "key-way" is fried thing.)
1. Grab ahold of that plug THEN crank away. One time will tell you yes or no on spark. No, I am not joking, and yes, it is better than staring at the end of a plug and wondering if your eyes are bad.
In fact, better than a cup of coffee......in a bad way.
2. Check your kill switch. It is either: Grounding, or Open (open like it should be, UNTIL you push it, click it, or slide it, whatever you got). One CHEAP and fast way: Unhook the kill switch.
Then crank away. No spark? Not the kill switch then!
3. Check your spark plug GROUND. Let's say you got some shocking results from grabbing onto that bad boy. NOW check where the plug meets the cylinder head when she is screwed down in there. Believe it or not.....if it is funky, she won't ground right!
Hence, no worky.
4. You got no spark at all.....STILL. Let's look over your Spark Plug WIRE. Is she wore through? Is SHE grounding out? Has she heat failed? Then do #5.
5. STILL no spark. Let's check the last 2 things......
Rotor Magnets, and Magneto (ignition coil).
IF you have a volt/multi-meter, hook her up to the plug wire. No juice = Bad Magneto, or Bad Plug Wire. SOME juice = Good Magneto, but Bad Plug Wire (in some mowers/weedeaters, etc., remember that the Magneto is where the kill switch hooks too.
See if it is somehow grounding you out, by being loose but still touching the cylinder, etc.)
6. Failing Magneto. This can happen, and it does. You get SOME juice, just not ENOUGH juice. 2-Strokes make a lot of heat, even Magneto's give up the ghost after a while, sometimes. In this case, find a replacement!
May 29, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Lands Phones Logo
95 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
