Question about Philips CDR795 2-Disc CD Recorder
Philips CDR796 CD Recorder
I have a a Philips CD recorder as detailed above. When turned on neither CD tray will open. The screen is asking me to insert disc but when I try to open either tray I get the message 'TRAYS LOCKED'. I have read the manual that came with it but could not find a referance to this. Are you able to tell me how to unlock thje trays please. Regards
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Posted on Jun 17, 2008
Wow glad someone knows thank you
Posted on Jul 17, 2008
  • 112 Answers
SOURCE:
Where can I buy it? ( CDR 796 )
These types of questions are best served by search engines that yield immediate answers.
There ARE newer models that are still available. I always shop eBay for older stuff.
Availability will change from time to time.
May 31, 2011 | Philips CDR796 2-Disc CD Recorder
Cannot unfinalize the CD RW disc.... I press ENTER to unfinalize but when the countdown arrives at 53sec it switches off and the disc remains finalized - please help !
clean the cdr with a cd cleaner if that doest work u mite need a new cdr. hard 2 find cdrs that work 4 philips am looking i got a cdr 788
Mar 15, 2011 | Philips CDR796 2-Disc CD Recorder
How do I finalise a cd on philips cdr 796
how do I finalise a recording , nobody has posted a solution , so the answer is press the record button
Dec 11, 2010 | Philips CDR796 2-Disc CD Recorder
When i put disc in it says disc error
the laser is not being able to read the disc put a cleaner disc through it or get it pro cleaned
Jul 06, 2010 | Philips CDR796 2-Disc CD Recorder
Phillips CDR 570
Let's start with an assumption... you're using ReWriteable discs.
What specific message do you get when you try to unfinalize it?
When finishing a recording, what does it display instead of "update" when you stop?
May 04, 2010 | Philips CDR796 2-Disc CD Recorder
Playback tray keeps ejecting when trying to load disc
I spent the whole night trying to fix this, all I could find was an unsafe workaround, involving this:
1/ Opening it up
2/ Find that upon forcing it in the the laser was not meeting with the ******* cd
3/ Sticking my finger at the bottom of the tray and lifting it up as soon as it loaded.
Now it works but only becuase I have to do the 1-3 everytime. Phillips also withdrew the Service Manual which is different to the normal one.
I could have gone and just brought a compatible drive from alibaba but no, phillips aren't having any of my Polish diy know how meddling with thier top secret **** you know what I mean?
Apr 03, 2010 | Philips CDR796 2-Disc CD Recorder
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Open close door not working
Nope. Does the red light come on on the front of the unit?It should then startup saying 'philips recorder'scrolling across the display. When you press to open it should click and say'open'on the screen. If it just says 'open' with no whirring or tray opening you can try a service mode test. If it displays 'locked'it's set to dealer mode that can be removed.
Jan 22, 2008 | Audio Players & Recorders
Trays locked
Hi, I had the same problem and i found out that if you hold down the fast forward and the rewind buttons with the power on and off button it will reset. It took me a couple of goes but after a while it worked. When you do it keep all of the buttons held down and a series of numbers flash for about a minute then it will reset. Good luck, Jeff.
Nov 15, 2006 | Philips CDR796 2-Disc CD Recorder
Philips CDR795 2-Disc CD Recorder Logo
838 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
