Question about Kenmore Dryers
I have a Lady Kenmore Dryer, model 86692120 that won't heat up. It turns blows but not heat. I have thrown circuit breakers, The vent hose is clear, I am afraid it's the heating element.... I did read
I have a Lady Kenmore Dryer, model 86692120 that won't heat up. It turns blows but not heat. I have thrown circuit breakers, The vent hose is clear, I am afraid it's the heating element.... I did read somewhere about a "plug" in the dryer that can get plugged from lint that then causes the heat to turn off. Does this dryer model have that? I now have the back off but don't really see anything. Any ideas? Also if we think it's the heating element, where would it be on this dryer? Thanks in advance!
4 Suggested Answers
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
Daniel S
  • 4323 Answers
SOURCE: panel lights seemed to be
Hi
I believe that everything else is fine rather it is the the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 03, 2011
Will not heat up
Basic instruction
Turn circuit breaker off thit can be checked for en back on, check dryer for heat.
If still no heat, (I am assuming that the dryer runs) There is a high temperature cut out on the heating element, it can be checked for continuity. the Heating element can also be checked. If this dose not help. I would need the brand and model number.
You should check the vent and make sure it is clear, I have had a lot of dryers that blow the fuse because of clogged vents.
Jun 20, 2015 | Dryers
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
My DV330AE will not heat up. I have had this unit since May 2010. I have pulled the venting hose off & check for clogs as well as turn the dyer on with the vent hose off blows out ok but no heat. I...
When resetting the breaker, you have to forcefully move to the off position to catch a tripped breaker. Push fairly hard to the off position and try again.
Jun 24, 2011 | Samsung DV330AE Dryer
Maytag electric dryer model MDE6000AYW dryer is running but not getting hot and drying clothes plus making a dining noise every couple seconds while running
Dryer Does Not Run
Your Kenmore Oasis dryer may occasionally not operate as intended. When the dryer does not turn on, check that the power cord is plugged into a working electrical outlet. Check your fuse box to make sure a fuse hasn't blown or the circuit breaker hasn't tripped. Replace the fuse or reset the circuit breaker as needed. Next, check that you have fully closed the dryer door; if not, the dryer will not run. Finally, make sure that you press and hold the "Start" button for at least five seconds.
Dryer Making Noise
Kenmore Oasis dryers will make noises that occur commonly with the running of the machine, including the motor and the sound of hot air blowing into the machine. Listen for uncommon noises with the running of the dryer, such as metallic clanking and excessive vibration. These noises indicate a problem with the machine.
If you hear metallic clanking, stop the dryer and check for any metal objects in the dryer drum. Often, change or other objects left in the pockets of clothing placed in the dryer will then fall out when the dryer starts spinning, creating the noise.
Excessive vibration often occurs when you have not properly leveled the dryer. To check whether the dryer is level, turn it off and try shake it frontward and backward, then left and right. If the dryer moves, adjust one or more of the legs needs to level the dryer: Determine which leg(s) you need to adjust and use a wrench to lengthen or shorten the legs. A level dryer will more quietly due to the elimination of vibrations.
Drying Time is Too Long
You may find that your laundry takes a long time to dry in the Kenmore Oasis dryer. This often occurs due to restricted the air flow within the machine. First, clear the lint filter. Clean it before every drying cycle to ensure proper air flow through the machine.
Next, run the dryer as usual and check the exhaust vent to ensure that airflows out of the vent. If you cannot feel air flowing through the vent, check it for blockage or damage. Clear any objects blocking the vent, or replace it if it has sustained damage.
The blockage may also occur in the exhaust hose attached to the back of the dryer. Unplug the dryer and remove the hose from the back of the machine. Clean out any lint or other obstruction and reattach the hose to clear the exhaust hose.
Mar 09, 2011 | Dryers
THE DRYER IS NOT GETTING HOT
Verify that all breakers (or Fuses) are fine, Electric dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Sometime, the dryer may heat, but it may not heat up as hot as it should. To repair, first check the vent hose. It must be clear for the dryer to work well. Make sure that the hose is not being crushed by the dryer. If the hose is very worn, or crushed, you'll need to replace it. The hose attaches to the back of the dryer and the outdoor vent with a spring clamp.
Another common cause of a dryer failing to heat is a faulty element (Heating Element). You'll need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Roper REX4634KQ Electric Dryer
I have a Kenmore (Whirlpool) Elite HE5 Steam front load dryer. Everything seems to work fine except there is absolutely no heat. I checked the breaker, and it wasn't tripped. I checked the lint filter and...
I think I know what the problem is, this actually happened on a dryer I repaired at one point. Low line voltage to me means that one or more hot leads is not feeding enough voltage to the heating elements (and the heating elements need both hot leads to run) which means the circuit breaker, although on, may be malfunctioning or weakening. You can check this by running your dryer and taking the cover off your circuit panel and checking voltage on the breaker. You should see 110V on each terminal to ground (put leads from one terminal to the grounding bar in the panel). If you see less than 110V on each lead to ground and less that 240V across the terminals it needs to be replaced. (You can get one for under $25.00 depending on brand). NOTE: THE BREAKER USUALLY POPS RIGHT OUT OF THE PANEL, BUT WHEN WORKING IN PANEL TURN MAIN BREAKER OFF TO THE HOUSE AND HAVE SOMEONE HOLD A FLASHLIGHT FOR YOU. IF YOU TOUCH THE LIVE BUSS BAR THAT BREAKER GOES INTO YOU WILL GET SEVERELY HURT. TURNING OFF MAIN BREAKER WILL DISENGAGE THE POWER FROM THE BUSS BARS; NOTE THAT MAIN WIRES ARE STILL POWERED SO BE CAREFUL.
Mar 22, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Old electric dryer started throwing the breaker and got very warm Bought a new dryer and breaker is still being thrown
It isn't your dryer OR your breaker.
It's your exhaust vent or ducting.
Check your Dryer vent tube for kinks/bends and dust deposits. I have even found dead squirrels in those.
Also make sure that if you use an extended dryer vent hose, that it has no severe angles or bends-Flats Spots etc.
In the unlikely event that it is the breakers, make sure your amperage rating matches the dryer it is attached to.
Mar 05, 2010 | Kenmore 62602 Electric Dryer
Does not heat I have cleared the vents and filter
if your dryer doesn't heat, check these:----
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 11, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer gets really hot, blows circuit breaker, vent is clean and clear, circuit breaker replaced, seems to be something that controls the heat isnt working..
Howdy: In back of the dryer is a thermostat (inside) that lint hangs to. If it reads too hot it should stop heating. If not working then blows breaker. Inspect please, we do not want a electric fire. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
Kenmore 90 series model 110 60902990
There is a thermal fuse in the back of the dryer, its usually white plastic, usually with 2 lite blue wires going to it.its probally blown...you can check it with an ohm meter......but if it is blown make sure you check the vent hose to make sure it aint kinked off that usually causes them to blow. if it aint that, be sure to make sure the heating element aint shorted to the heater box.or the thermostats aint stuck....the thermal is a safety feature and something caused it to blow
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
128 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
