SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
SOURCE: ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
SOURCE: GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
