Washer overflowing need help in locating/removing water level awitch...amdiral M# LNC6762B71
  • tj75woods Apr 26, 2009
    THanks for the reminder....had similar issue several years ago. pulling, cleaming out and reattaching hose took all of 3 minutes and solved problem.
  • 1,029 Answers
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Posted on Apr 18, 2009
Lxr6232eq0 whirlpool washer timer does not continue cycle and overflows?
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Mar 12, 2015 | Whirlpool Washing Machines
Why does my washer overflow and not agitate?
Jul 29, 2014 | Whirlpool Inglis IP4400 Washer
Simpson top loader overflows
Feb 21, 2014 | Frigidaire FGX831C Top Load Stacked Washer...
Washer overflows
Feb 13, 2014 | Frigidaire FGZ831A Top Load Stacked Washer...
My maytag washer is overflowing and won't go into
Hello there and welcome to fixya
This is a fairly common problems on these and other machines
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please feel; free to post me back any comments on repair help or testing and removal ian installation if needed ill be glad to help you ok
Best regards Mike
Apr 09, 2012 | Maytag Washing Machines
Code fe
FE Over Flow Error
Water is overflowing (water level frequency is over 213).
If FE is displayed, the drain pump will operate to drain the water automatically.
(may be too much suds ...)
WM2277HW Service Manual HERE...
Or
Locate your service manual behind the kick panel of the machine.
FE means overflow condition.
Before replacing the fill valve sand or trash may have gotten into the tube going from tub to water level switch.
So find that hose and blow it out. Remove the standing water and retry.
Thanks for using FixYa!
Jan 12, 2011 | LG WM2487H Front Load Washer
I have a Kenmore 80 series washer. It has 4 settings for load size. If I do not put the dial exactly on the dot the water will continue to fill and overflow. Shouldn't there be some kind of overflow sensor...
The sensor that determines the water level and shuts it off, is called the pressure switch. It is located behind the load level sector knob you are having problems with. You will need to remove the back of the control panel to access it. The following link explains what can cause the washer to overflow:
http://www.fixya.com/support/r762094-washer_overflows
With the washer unplugged, examine the pressure switch to ensure the electrical connections are clean and making good contact. Then, check the small air hose that runs to the bottom of the wash tub. A simple test to determine if the hose has a leak or not is to put a small amount of water in the wash tub (about 1/4 full) and shut off the washer. Disconnect the air hose from the pressure switch and blow air in it. You should get air bubbles in the wash tub of the air hose is good. If not, you need to replace the air hose. Small leaks can affect the pressure switch ability to properly sense the water level and shut off.
If the preliminary checks provided in the link I gave you do not work, replace your pressure switch. It could be that the switch is simply worn out and operating erratically. They aren't that expensive and its an easy repair.
Replacements can be purchased at any of the following web sites:
Searspartsdirect.com
Appliancepartspros.com
Pcappliancerepair.com
Repairclinic.com
Some of these sites also have some helpful exploded view diagrams to assist you in your repair. Use your model number for your search criteria.
If you have questions about this repair, or need additional assistance, please let me know. I hope you find this information helpful.
Aug 31, 2009 | Kenmore 24032\24036 Top Load Washer
Ultimate Care II - water doesn't stop at the fill line, keeps filling to overflow and will not agitate
If the washer overfills, it may be something as simple as a detached or broken air hose on the pressure switch. The following link explains:
The pressure switch on top loaders is located behind the load level selector knob on the operator console. The pressure switch on front loaders will be located inside the cabinet, usually mounted along the back interior wall. In the case of certain Maytag front loaders, the pressure switch is actually located under the tub. The principles of operation on all of them is the same, though. They all have an electrical connection and an air hose that detects the pressure from the tub as the water level rises.
If the pressure switch is not able to detect the water level properly, it will not shut off and the washer will never begin the wash cycle. Instead, you get a tub overflowing on your laundry room floor.
Read through the link provided and let me know if you have any questions. I hope this helps you.
NOTE: Another source of an overflow could be the water inlet valve. This is usually a slow fill fill that you find when the washer is sitting idle over night. A quick test to determine the source of the problem is to unplug the washer. If the water stops - pressure switch. If the water continues to fill - water inlet valve.
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer tub overflows and wont stop
The water level in a washing machine is determined by the pressure switch. The switch is located behind the load selector, water level, load size (has various names depending on model and manufacturer) knob on the operator console. If the switch malfunctions, the water will not shut off and the washer will overflow.
Now...before assuming the switch is defective, a common problem that occurs is the small air hose on the pressure switch coming loose or leaking. This air hose attaches from the wash tub to the pressure switch. The pressure swtich senses the change in air pressure as the tub fills and shuts the water off at the selected level. The following link explains:
To access your pressure switch, unplug the washer and open the operator console. Look for a clear plastic hose. If it is NOT attached, you may have found your problem. Reconnect and test operate.
If it IS attached, check the entire length of the hose all the way to the wash tub for any cracks of leaks. In addition, remove the electrical connection(s) and check for corrosion. Clean if necessary.
If all these preliminary steps don't solve your problem, replace your pressure switch. Read through the link I provided and let me know if you have any questions. I hope you find this information helpful.
Jun 10, 2009 | GE WBSR3140DW Top Load Washer
Admiral Top Load Washer Model LNC6762B71 overflowed
Feb 28, 2009 | Admiral AW22 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
