Question about Siemens 24 in. SE20A591 Slim-Line Free-standing Dishwasher
Siemens SE20790GB/02 Dishwasher FD 8005
Error message ' wrong couple ! ' has appeared since we had a power cut. Machine was off at the time, working perfectly beforehand and recently serviced. Tried switching off and on at mains, in the hope that it would reset itself. Called out my local repairman, who checked all obvious things, then called Siemens tech. dept who said they had never heard of this message. Electricians tested power supply to socket; that is fine. Has anybody got any ideas?
5 Suggested Answers
SOURCE:
  • 6 Answers
SOURCE: SIEMENS SE64630GB NOT TAKING IN WATER
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Posted on Aug 15, 2008
  • 4 Answers
SOURCE: An electrician switched off the power whilst doing
Maibe the internal fuse of the dishwasher blow for a spike, check first if you have power at the socket if so is highly posible that you have a blown fuse in the dishwasher
Posted on Nov 13, 2009
  • 414 Answers
SOURCE: Siemens dishwasher pump runs while door open wont turn on!
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. There may be water in the base of the d/w (base as below the tank, not under the filter) this will activate the flood safety and give the scenario you have described, so check valve, hoses etc for leaks. You will have to manual clear the water from the base pan to deactivate the safety device. Sit the front of the d/w on a large tower and tip the whole unit forward, the base water will then come out. Whilst you have the side panel off, check that the red rod connected to the pressure chamber is not activating the microswitch. https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
Posted on Jul 12, 2010
Daniel S
  • 4323 Answers
SOURCE: I have had an
Hi Steve
E24 error normally indicates failure to drain, the first thing to check is that the water is actually being supplied to the appliance and is turned on. If it is then check the water inlet valve, if the valve tests fines then clean the drain pump assembly completely as that might be clogged causing this issue. Hope this helps...please post back for further assistance.
Daniel
Posted on May 31, 2011
Printonix p 500 error papfd drvr cir
Paper Feed Driver Circuit. The paper feed driver circuit on the controller board is drawing too much current.
1.Cycle power. If the message appears, replace the controller board. Record the message and return it with the defective board.
2.Power on the printer. If the message appears, replace the paper feed motor.
Jan 20, 2014 | Printronix Line Matrix P5005B Printer
Burning Smell inside siemens dishwasher
Most likely the smell is coming from a motor that is having a hard time turning, so it's overheating. Don't run it or it might catch fire!
Apr 22, 2017 | Siemens 24 in. SE64A630GB Built-In...
What does E 15 mean on an under the counter Bosch dishwasher?
Had the same problem.
there is water in the base of the machine, and all that is happening now is the pump to drain the machine is working. If you can manage this next bit physically, the quick temporary solution is to turn the machine off at the mains, empty the machine of contents, and in my case, I had to pull the machine out, and drain the machine by tipping it about 45 degrees by lifting the front of the machine. The water will drain out the back of the machine ( I managed to place some cardboard underneath the machine to soak it up) and once drained of the small amount of water, let the machine go level again.
when I turned the machine back on, it functioned normally again for a while.
eventually had to call in a repairman, as it continued to malfunction every couple of weeks. In my case his initial diagnosis of a split container was wrong, and after he took the left hand side of the dishwashing machine off, he has found that the hard water has clogged a component which needs replacing.
i got the quick fix method on YouTube, either by typing the E15 Bosch dishwasher fault on google, or going directly to you tube.
Jan 22, 2018 | Bosch 24 in. SHU43 Built-in Dishwasher
SIEMENS DISHWASHER ERROR CODE E15 WITH FLASHING TAP SYMBOL. WILL NOT SWITCH OFF WITH ON/OFF SWITCH OR BY OPENING DOOR ,FULL OF WATER. LEAKING FROM LOWER FRONT CORNERS BELOW THE DOOR.
1 Turn off power
2 Remove lower front cover next to floor.
3 remove soundproof padding
4 Look in left of centre and you will see a white plastic tray with a circular float that Bob's up and down when you touch it..
5Check worth your fingers and you will notice about 6mm of water in tray.
6 Using about 6 to 8 sheet of paper kitchen towel, fold two sheets Kat a time into a flat pad, Using your fingers insert pads into tray and rock up all the water.
7 Turn on power ,and machine works.. .
The problem is caused by a small leak from the drum which is repairable however the above cure will last quite some time unless you have a serious leak.
Sep 01, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
Have hot tub with Spabuilders heating unit not functioning and getting two messages (1) FF 04 & (2) Fd 02
FF 04 and FD 02 might not be error codes.
In the UK, 'FD' stands for either 'Filtration Duration' or 'Filtration Delay'. As I'm not in the office right now I don't have a manual at hand.
Why isn't the hot tub functioning correctly??
Common Spa Builders (Gecko) error messages are, OHH, FLO, FLC, Sn1 and Sn2. Also they have three flashing dots which can appear on the display.
Kind Regards,
Ian Kime, from: http://hottub.synthasite.com
May 26, 2010 | Pool & Spa
An electrician switched off the power whilst doing other work. Power was restored OK. But when we came to use the dishwasher there appeared to be no power to it i.e the control panel remained blank. We...
Nov 13, 2009 | Siemens Dishwashers
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Siemens 24 in. SE20A591 Slim-Line Free-standing Dishwasher Logo
233 people viewed this question
Top Siemens Dishwashers Experts
luvduct-tape
Level 1 Expert
Paul Bade
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
