Question about Samsung TX-R2735 27" TV
Samsung colour Tv Power is up and Down
Samsung Tv stand by lite is up and down,
  • howel Nov 06, 2007
    The power of my tv is up and down.
  • wtz1973 Dec 12, 2007
    The TV power does not work sometimes and goes out when you are watching other times.
    Sansung TX-R2735
There is atransistor in the power area it works like aswitch chamge it after checking all the capacitors in the area...........
Posted on Sep 18, 2007
Volume bar stands at 200 every time i start my Samsung LCD
set the volume down extremely low power the tv down by plugging out and put on again should be then at set volume,the tv's now days have memory so it should start up at volume preset
Dec 21, 2013 | Samsung LN-S2651D 26 in. LCD Television
Bad picture
Sounds like the DLP chip has failed. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 14, 2018 | BenQ Televison & Video
Samsung LC32C350DLD won't power on, red power lite is on but remote and button on tv does not turn it on! Blown power board?
it may be the stand by chip on the main board check that there is volts getting to the standby side of the main board.also check power board for weak capacitors in line.
Sep 21, 2013 | Samsung Televison & Video
Samsung LCD TV colour distortion
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung Televison & Video
My TV suddenly lost strong color and is washed out when operating with the satellite receiver. When I use with DVD player, the color is fine. Could I have accidentally pushed a button to cause this.
you can set colour go to menu then picture setting select colour function by useing remote up/down. set colour as you like.or use picture mode like vivid,stander,coustem.i hope you under stand.
Oct 25, 2010 | Sony KLV32S550AE 32 in TV
Red stand by lite blinks 3 times an then on an off with power on tv will not turn on
this is an indication that the lamp door is open or loose. or might be a lamp but i suggest making sure the lamp door cover is screwed down first
Oct 13, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv turns on but no picture or sound. none of the controls work including menu, on or off. The only way to turn off is to unplug.
AC input power is ok but monitoring circuits detected a change in value and shut down DC output. This means a problem has developed in your tv and to prevent further damage to the tv and risk fire hazards. The tv is designed to shut down from component failure, or interruption in circuit functionality.
In your case the DC power is held-down, logic and memory functions are all on stand-by as designed. Therefor user commands like menu, power, vol,...etc are all canceled, and is the reason why you have to remove the ac-plug to power-down the tv. To test and fix this problem requires some technical understanding of electronic circuits. If you know someone who's technically proficient, have them send me some pictures of your boards and I will hi-lite what circuits to test first....
If you were here I'd fix it for you, but this is the best I can do over the internet :-)
Let me know if any questions...
Nov 28, 2009 | Vizio VP422 42 in. Plasma TV
I NEED SCHEMATIC DIAGRAM FOR PRECISION COLOUR TV MODEL PTF29R99S
cannot get no parts for this tv ptf29r99s precision
Mar 03, 2009 | Televison & Video
Tx 26lxd70 panasonic lcd
I had the same issue with my Samsung LN52A550. The 4 screws holding the TV stand are quite small and deep inside the holes. You can not take the stand off without take them out completly. I tried to remove them with magnetic screwdriver, tweezers but didn't help. So, by laying down my TV on its back on my sofa letting the TV bottom and the stand parts outside and lay down beneath to unscrew them again. With the grativity, some screws fall out right away, some may need unscrew a little bit more or shake the stand a little bit. I could say it's a very bad design about this screwing system. So, good luck then.
Jul 06, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung TX-R2735 27" TV Logo
51 people viewed this question
Jerry Greenberg
Jerry Greenberg
