Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Printed pages are comming out pink and striped
The machine said it was out of ink so i bought some put it in the machine then had faxes come through but they were extremely light pink and striped. what happened to it? what would i need to do? i would really appreciate yur assistance. thank you
  • 88 Answers
Scanner must be cleaned. Unplug the machine, close the document support and the document
tray and then open the top cover. Clean the flat white plate and the
glass strip below the bar with isopropyl alcohol on a lint-free cloth.
Posted on Apr 18, 2009
Why when the fax machine prints is some of the ink lighter than the rest?
It sounds like the print head(s) is clogged and needs cleaning. Another potential problem is the wrong ink or a defective cartridge. They ARE different. If you refill the cartridges be sure the ink is compatible with the printer.
Often simply running the built in 'head cleaning' test will clear out the partial clog.
Jul 23, 2014 | Brother Office Equipment & Supplies
Stripes all over page
one or more of the cartridges will most probably be out of ink, make sure all cartridges contain at least a 3rd of ink and if they do then perform a head clean followed by a nozzle check, if the nozzle check print is not perfect then do another head clean nozzle check & repeat the process until you get a perfect print on the nozzle test pattern.
If that is not the issue then I suspect driver corruption and you will need to un install then re install your printer drivers
Jan 14, 2014 | Epson Stylus RX500 All-In-One InkJet...
Faded Stripe in the middle of the page
You need to clean the drum When I was working for the City There was the same problem with the Laser printers. Check the Manuel and see if there is a page on cleaning the print drum on your machine. Also you may try Talking the cartage out cleaning there as well It seems you are picking this up form somewhere after the print My Guess would be the print drum? You may also have to replace the drum as well. I am guessing that this is a laser printer? if not then there are other solutions.
Jun 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Canon fax-B840 - Print is "stripey"
No not yet,the problem is the cartridge,sometimes even new cartridges might have a dry printhead
Remove you cartridge,put the printhead side in about 5mm of hot water and keep it there for 5 minutes,take it out and do head cleanning again.
Mar 12, 2009 | Canon FAX-B840 Plain Paper Bubblejet
Hp 7310
If the color cartridge doesn't print the color bars on the alignment page (either, redish pink, yellow or blue) then the alignment process will not finish. Same for the black. If the black cartridge is printing ok, then replace the color cartridge and try this again...
Jan 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Black stripes ove the page
Try cleaning your ink nozzles or ink jets. It sounds like you have a plugged nozzle or two. Your printer program should have maintenance options that allow you to test for plugged nozzles and clean them.
In control panel, open the printing/fax icon, right click on your printers icon, left click properties, then on the bottom of the page the panel that opens you will see a button that says printing preferences, and that should open your print program.
Dec 15, 2007 | Epson AcuLaser C900 Printer
HP 20 ink refill problem
Did you try a new ink cart? Most print problems with inkjet machines are refilled carts.
Nov 18, 2007 | Brother IntelliFax-2820 Laser Fax
Deteriorating Print Quality
This is Maltesecross. Turns out that the faintness of my printed pages was in fact due to a low ink cartridge, even though some pages printed out fine and others half-good. Eventually, all pages turned faint, and upon re-installing the driver, I got a low-ink warning (the first one ever). Putting in a new ink cartridge solved the problem for me.
Oct 21, 2007 | HP Photosmart C3180 All-In-One InkJet...
White "Stripes" across page
REPLACE PAPER AND THE INK CARTRIDGE
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
120 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
