Question about HP Office Equipment & Supplies
HP CM8060 Error code C1.132A
I get this code C1.132A paper jam drum. But there is no paper on drum.
  • 44 Answers
2 possible causes for this are Carriage stall and paper on drum at SN57 Carriage 2 Pen Protection sensor. Some MFP's can experience intermittent motor stalls due to maladjusted upper right front door latch when minor movements cause the door actuator to open the door switch . this can then show up as a carriage stalled. also check for carriage 2 binding and that the aerosol hose and snorkel are seated properly.Check the plastic sensor actuator for damage and contamination. last chance could be Pen Pocket 4 PCA (A19).
Posted on Apr 19, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
Jan 14, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp 9050n paper jam 13.32
check the censor 1, pick up 2,in fixing these should the spring tentioned
Feb 18, 2013 | HEWLETT-PACKARD HEWLETT PACKARD : HP 8-bin...
Jam inside top cover 13.05.00 also change fuser assembly
To remove paper jam. Just remove the toner cartridge and pullout jammed paper. If still coming paper jammed error message. Switch of the printer and the printer will roll over the paper jammed.
Changing of fuser drum is required if the print out came with the black strips. This happens when you print large volume of printing jobs.
Nov 26, 2010 | HP LaserJet P3005 Printer
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Paper jam and error code e012 on ir6000
You could very well have a worn registration clutch, it's behind the the gray roller that sits to the right under the drum. Good luck! If that doesn't do the trick you may have to change your transfer settings in service mode
Oct 14, 2008 | Office Equipment & Supplies
59.0A error in hp color laserjet 3700
All 59.XX error codes have to do with a motor failure of some type. I don't know anything specific about 59.0A but 59.A0 means that either the drum motor failed to start or something bad happened while it was rotating. If you feel like tackling it yourself you can try reseating all the connections to the drum motor and the DC controller board. Other possibilities could be a bad drum motor or a bad DC controller. HP says you can also get this message when the tranfer unit is missing or improperly installed.
If you don't feel like tackling it yourself then it's off to a repair shop unless it's under warranty, in that case call HP.
Jan 19, 2008 | HP Color LaserJet 3500 Printer
E studio 16
More than likely you have bad feed tires in the tray you're pulling from or if the drum unit is stuck there probably is paper jammed up in the unit.  Replace you feed tires and check your drum separation claws when you are able to get the drum unit out.
Oct 11, 2007 | Toshiba e-STUDIO 16 Printer
259 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
