I've just installed the powerbolt 1000 and the only way it locks and unlocks it with the key in the dead bolt.
SOURCE: lost my instructions to set-upp my Powerbolt 1000 lock
1. Remove Plastic cover on interior side of lock
2. Press Black Pushbutton one time
3. Enter User Code on keypad
4. Press Lock Button on keypad
5. Press Black Pushbutton one time
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
SOURCE: dead bolt trys to turn in the same direction
Hi.
I think it can be possible that the bolt assembly is installed upside down.
Remove the unit, and refit with the bolt and faceplate the other way up.
Test WITH THE DOOR OPEN. to ensure correct function.
I am not familiar with this lock - but other weiser locksets can suffer the same problem if a deadbolt is installed inverted.
SOURCE: powerbolt 1000 does not accept
you are too slow, i called a locksmith. h drilled out te key entry and openedthe lock. then he replaced the key entry with a new one. i was hping that you might hav known the master code. thanks anyway. please note that i will not accept any charge for your involvement in this affair.thanks again, isadore
SOURCE: Powerbolt 1000 started beeping and quit functioning
To provide a further bit of information. According to tech support the beeping can be caused by EITHER a bad keypad (about $15) or a bad circuit board (about $80, so, time for a new lock). The easiest way to tell is to:
After powering back up, if the unit keeps beeping, the circuit board is bad. But if it doesn't the keypad is bad. You can order the replacement keypads from Weiser via the 800 number listed in the previous comment.
