Question about Sony Handycam DCR-TRV350 Digital Camcorder
How do you set the clock and the auto-focus isn't working...?
How do you set the clock on the sony trv350 handt cam? The auto focus isn't working either...?
  • 107 Answers
Heres a link to your cameras OM....check page 26 for setting time and 68 for using auto focus
http://www.docs.sony.com/release/DCRTRV350.pdf
Posted on Apr 18, 2009
Autofocus problem with 70-300mm is usm
Replace the broken ribbon cable in the lens
Sep 23, 2012 | Canon EF 70-300mm f/4-5.6 IS USM Lens
LENS AUTO FOCUS NOT WORKING
Gee I have one of these. Nice camera too.
Check you don't have the auto focus switch on the left side of the lens barrel switched to manual. I've knocked that switch when getting it out of my bag and it took me a minute to find the fault. Very easily knocked so keep an eye on it. Go through your menu and make sure everything is as it should be. If everything checks out I'm afraid it's a Sony repair agent you'll be saying hello to. I wouldn't advise trying to pull it apart yourself unles you are confident. I pulled my second one apart and had a great time getting it all alighned to put back together. Mainly because I pulled it down one week and waited another 3 weeks until I tried reassembling it. Always try to reassemble straight after fixing it. Don't give that brain time to forget important parts and where they go.
If there is a fault it would be in the lens area but after owning 2 of them and the 818s I found no problems in this area and never had a customer have any problems there either. But there's always a first time.
Try that darned switch first though. One other thing it's just possible to try. Make sure your battery is fully charged and in good health. They can cause some weird faults if the voltage is getting low. The focus motor does draw a bit of current.
There's another thought. If the auto/manual switch isn't the culprit. Actually switch it to manual and see if you can focus it by hand. If you can't then it's definitely something major and one last thing. Check your Diopter.The little adjustment alongside the viewfinder. If this is out of adjustment it will give an out of focus blurry look too.
If this has been of any help would you mind letting me know what the exact fault was. It will come in handy with mine. Thanks and good luck
Apr 23, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
How do you turn off autofocus on Mini DV Sony Handycam?
this is how you disable autofocus for this camera, first set cam to camera mode.using touch panel screen:
1.press FN to display PAGE1
2.press FOCUS
3.select and press MANUAL
4.select and press (icon of person) when subject is too close to focus on or (icon of a mountain) when recording distant subject
5.press (return arrow w/OK) to return to PAGE1
hope this info helps.tnx:)
Apr 16, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
I don't have the software for the Sony Digital 8 Handycam? How can I make the computer see the handycam
Hello :
Please chick this link to download the software of your cam but don't forget to choose your OS first .
PLEASE DON'T FORGET TO RATE !
Apr 11, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Problems with Sony DCR-TRV350 Camcorder and Vista
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV350&LOC=3
you say you tried to update driver , tried as in you didn't succeed in getting the update driver ?
i noticed at the sony site they have vista drivers for the dcr-trv350 , here is the link . thanks.
Dec 27, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Firewire port problem
Please replace the Port-Connector of camera.
Aug 01, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony Model DCR-TRV350 Tape stuck in camera.
take out the battery, put it back, turn it on and you take the tape out of the camera. hope this helped you. have a great day.
Mar 03, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony Handycam DCR-TRV350 Digital Camcorder Logo
178 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
