Inter Vlan routing
I have 1 DLINK Layer 3 switch and 2 Dlink Layer switch model No. are mentioned below. The problem is i am not able to perform inter Vlan routing.I have created 2 Vlans on Layer 2 swtich as well as on Layer 3 switch and did all the reuired configuration . but still not able to communicate across Vlans. Could plz anyone can help me out to solve this issue with reqired details and configurtaions.
  • Tony88 Feb 14, 2008
    I am unable to establish network connection between between the switch having 2 vlans and a cisco 2620 series router.
  • ramirs Apr 04, 2008
    Same Problem here, I used to make this on cisco switches, i use only the command "ip routing" to ensure the inter-vlan routing. but i wasn't able to do that in DLINK
Just For InterVLAN routing, Mark (enable) administration Access for ALL VLAN :P
Posted on Apr 23, 2009
  • 118 Answers
Please post the model of your dlink switch
Posted on Feb 07, 2008
Hi,this is pavan i want to b configure the HP procurve 2626 J4900B managed switch pls help me through anybody by giving the programme to configure it
What do you need it configured to support? Multiple subnets? VoIP support?
Here's an example to support 2 subnets, VLAN 1 Data and VLAN 2 Voice. This switch is the VLAN router for the site and it is also the default gateway for all the devices on the network.
show running-config
Running configuration:
; J4899A Configuration Editor; Created on release #H.10.50
hostname "HP 2650 dot 11 layer 3"
snmp-server contact "Your contact info here"
snmp-server location "Server Rack - Upper Switch"
time timezone -5
time daylight-time-rule Continental-US-and-Canada
interface 49
name "Uplink to HP2650 port 49 -"
interface 50
ip routing
timesync sntp
snmp-server community "public" Unrestricted
vlan 1
name "Data"
untagged 1-46
ip address
ip helper-address
tagged 49-50
no untagged 47-48
vlan 2
name "Voice"
untagged 47-48
ip address
ip helper-address
tagged 1-46,49-50
ip route
spanning-tree Always turn on Spanning Tree
spanning-tree priority 0 This switch is the master Spanning Tree operator.
password manager
password operator
Sep 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Inter-vlan routing
Unfortunately, the 5224 is a Layer 2 switch. In order to route between VLANs, you need a Layer 3 device somewhere else on your network. In other words, either a true router, or a multi-homed PC acting as a router, or a true Layer 3 switch. The 5224 is incapable of routing within itself. Sorry!!
Nov 09, 2009 | Computers & Internet
How to create vlan in nortol 3510 L3 switch
You would need to trunk the VLANS to the router and create sub
interfaces and then, create access lists applied to
the interfaces to control inter vlan communication. I hope this helps,
Router interfaces something like this, may not work on all versions of
interface FastEthernet0/0
no ip address
speed 100
interface FastEthernet0/0.1
description VLAN1_Servers
encapsulation dot1Q 1 native
ip address
interface FastEthernet0/0.2
description VLAN2_QA
encapsulation dot1Q 2
ip address
interface FastEthernet0/0.3
description VLAN3_DEV
encapsulation dot1Q 3
ip address
interface FastEthernet0/0.4
description VLAN4_FIN
encapsulation dot1Q 4
ip address
Aug 01, 2009 | Nortel Enet Routing Switch 3510-24T Incl...
Connection error
can you clarify the switch configuration, by default it will have all ports as untagged in the default vlan 1 with a bootp/dhcp address, I assume you will need to perform some kind of routing ie; default gateway, ip-helper address or static route to point to your routing device ADSL router etc try the following;
1~ configure an ip helper address on vlan 1 to point to what ever is supplying dhcp
2~ create a defualt route on the switch ie; to next hop / routing device
3~ configure a default gateway ie; ip default-gateway x.x.x.x where x= routing device
the above can be accomplished via a serial connection to the switch using hyperterminal with the following settings
bits per second 9600
data bits 8
parity none
stop bits 1
flow control none
let me know if this resolves the issue
Mar 13, 2009 | HP ProCurve 2524 24x10/100 Mbps Networking...
Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
Oct 28, 2008 | 3Com 4500 24-Port Ethernet Switch
Dlink dgs 2208 switch
pls check your connection between the switch and the router,dsl,access point.
2.make sure the gateway router is receiving good signals
Apr 12, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Here is the link to download the user guide (it thoroughly covers configuration) for you Dlink DES 3225G Layer 2 24 port switch in .pdf format (you'll need Adobe reader to use it, and you can download a free version at Adobe's site if you don't have it): Here's the link:
Good Luck.
Feb 25, 2008 | D-Link DES 3225G Networking Switch
Computers & Internet Logo
3,774 people viewed this question
David Payne
David Payne
