FixYa.com
Tags:
Eclipse 5443
I closed my Eclipse editor after usual work; and i...
posted by santh on Sep 18, 2007
!ENTRY org.eclipse.osgi 2007-09-18 11:44:19.844
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (23).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.compatibility.PluginActivator.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:1013)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:969)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:313)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:255)
at org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLocalClass(EclipseClassLoader.java:116)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:337)
at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackage.java:37)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:386)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:350)
at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader.loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClass(Ljava.lang.String;)Ljava.lang.Class;(Unknown Source)
at java.lang.ClassLoader.loadClassFromNative(ILjava.lang.String;)Ljava.lang.Class;(Unknown Source)
at org.eclipse.ui.internal.ide.model.WorkbenchAdapterFactory.<init>(WorkbenchAdapterFactory.java:35)
at org.eclipse.ui.internal.ide.model.WorkbenchAdapterBuilder.registerAdapters(WorkbenchAdapterBuilder.java:33)
at org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.initialize(IDEWorkbenchAdvisor.java:133)
at org.eclipse.ui.application.WorkbenchAdvisor.internalBasicInitialize(WorkbenchAdvisor.java:172)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1023)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1707)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:376)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:106)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:165)
Caused by: java.lang.NullPointerException
at org.eclipse.core.internal.utils.FileUtil.toURI(FileUtil.java:94)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.getStoreRoot(FileSystemResourceManager.java:349)
at org.eclipse.core.internal.localstore.FileSystemResourceManager.getStore(FileSystemResourceManager.java:332)
at org.eclipse.core.internal.resources.Resource.getStore(Resource.java:1004)
at org.eclipse.core.internal.resources.AliasManager.addToLocationsMap(AliasManager.java:337)
at org.eclipse.core.internal.resources.AliasManager.addToLocationsMap(AliasManager.java:330)
at org.eclipse.core.internal.resources.AliasManager.buildLocationsMap(AliasManager.java:366)
at org.eclipse.core.internal.resources.AliasManager.startup(AliasManager.java:570)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:1862)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:1631)
at org.eclipse.core.resources.ResourcesPlugin.startup(ResourcesPlugin.java:365)
at org.eclipse.core.internal.compatibility.PluginActivator.start(PluginActivator.java:31)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:994)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:988)
Root exception:
!ENTRY org.eclipse.osgi 2007-09-18 11:44:19.906
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IProject
at jrockit.reflect.InitialMethodInvoker.invoke(Ljava.lang.Object;[Ljava.lang.Object;)Ljava.lang.Object;(Unknown Source)
at java.lang.reflect.Method.invoke(Ljava.lang.Object;[Ljava.lang.Object;I)Ljava.lang.Object;(Unknown Source)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338)
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.osgi 2007-09-18 11:44:19.922
!MESSAGE Bundle update@plugins/com.quantum.Quantum_3.0.3/ [7] was not resolved.
!SUBENTRY 1 org.eclipse.osgi 2007-09-18 11:44:19.922
!MESSAGE Missing required bundle org.eclipse.gef_0.0.0.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these In Dash Receivers problems?
In Dash Receivers
code for cd player
can i know the code for honda... Answer This...
In Dash Receivers
Radio Code
I need help getting my radio... Answer This...
In Dash Receivers
How does one hookup to xm radio...
I have the radio no manual need... Answer This...
Eclipse 5443
NO DISPLAY
every thing works but display. Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
