Hoover Elite 1205 washing machine
Hi, when moving to new house, we dropped the washing machine and the power cord was disconnected from the machine. There are 3 wires that need to be reconnected. There are a number of points that they can be fitted to. Was wondering if you have a diagram of how these wires are connected, so that I can just reconnect them. Thanks
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Posted on Jul 13, 2010
Hi, i have ONHF 6117 Hoover washing machine which dropped out of my van while moving house the problem is there no motor action, i had someone look at it he changed the pcb module board, motor and pre
All washing machines have a switch that is activated when the lid or door is closed. This tells the machine its safe to run the motor. If this thing dropped out of a van, it's possible the housing twisted and the little metal bracket on the door is not making contact with the safety switch or the switch may now be broken.
Nov 25, 2014 | Hoover Washing Machines
Hi, i have ONHF 6117 Hoover washing machine which i dropped while moving house the problem is there no motor action, i had someone look at it he changed the pcb module board, motor and pressure switch
door switch comes to mind, how far was the drop ? does the lights or motor buzz ? did the power cord get pulled on ? check with a volt meter at were the power cord attaches to the unit. GOOD ? = then check every last plug in the unit, to make sure it is seated properly into it' respective socket.
Hope this gets ya running again. ask if you need more help, and don't forget to vote if i was of help
Nov 25, 2014 | Heating & Cooling
Hoover 960 elite washing machine
contact manufacturer they should be able to help you
Aug 25, 2014 | Washing Machines
Hoover elite 960 washing machine everytime I turn on power for house goes out
Did this just start? If so then there is a big short in the machine or you have added something to the circuit that it is plugged into. I am concerned when you said that it shuts off the whole house.
Aug 09, 2014 | Washing Machines
Hoover elite washing machine
FIXYA has no idea of any parts for hoover machine . contact hoover direct
Oct 23, 2017 | Washing Machines
Hoover wind tunnel can the dirt cup be washed it smells horrible and I am moving to new house and dont want to stink up the house with this vacuum I hate to go out and biuy a new one as this one is on
yes you can wash the dirt container in worm soapy water,rinse off and make sure it's absolutely dry before you use it again.this link is for the manual if you need it. good luk in your new home.***
http://hoover.com/file/570/
Sep 21, 2012 | Hoover WindTunnel Rewind T-Series UH70120...
How to replace water inlet valve on a hoover 500M washing machine?
To replace your Hoover washing machine water inlet valves watch this instructional video http://youtu.be/78D5ieegS98
Or follow the instructions below
Turn of the power at the power point and disconect cord.
Turn of water supply to the machine.
Disconnect the water hoses
Unscrew the screws on the rear cover and remove
Use a screwdriver to press in the inlet valves plastic locking clip
Pull the inlet valves upwards and disconnect spring clip electrical terminals
Push in new inlet valves and connect spring clip electrical terminals
Reinstall plastic locking clips
Reinstall rear cover and reinstall screws
Reinstall water hoses and turn water on
Reconnect power cord and switch power on
Aug 02, 2012 | Washing Machines
Error code E11 on hoover washer dryer vhw854d
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Nov 12, 2010 | Hoover Washing Machines
I need a new lid for my hoover elite 1205 washing machine toploader!
Please post a complete model number when submitting questions. This makes it easier to locate parts and determine how your appliance is configured.
You can usually find replacement for nearly any brand at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service. Prices vary, so shop and compare. The first three sites on the list also offer excellent exploded view diagrams to assist you in parts location/identification.
If you have any questions, please post back and let me know. I hope this helps you.
Jan 14, 2010 | Washing Machines
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
448 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
