Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
My kenmore frig is not staying cold in frig. or freezer
I have power because my light is working not sure what the problem is with the coldnest it is only 5 years old
  • 1,169 Answers
Also check the defrost element in the freezer side mounted on the evaporator coil. They tend to burn out over time causing the coil to freeze up causing the same problem.
Posted on Apr 20, 2009
  • 465 Answers
One of the most common problems with refrigerators and freezers is over time dust and lint can accumulate in the condenser coils try cleaning the coils CAREFULLY! with a vacuum. Unplug the unit before doing any cleaning . most units have a cardboard cover in the back, remove this to get at the coils . also check the fan(if there is one ) to see that it is not stuck.replace cover and plug unit back in.
check to see if fan is running and for air movement under the front door of unit. Keep in mind all models are different and these solutions are generic ones .Hope this helps.
Bobalix
Posted on Apr 18, 2009
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore coldspot - freezer stays cold, but frig isn't
If this model is a frost free, you probably have a bad defrost system. That would make the unit freeze up and cold air can not get through to cool the unit properly.
We have parts and supplies, so please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We look forward to working with you.
Nov 05, 2009 | Refrigerators
Frig is staying at 64 degrees, freezer is very cold, it is a whirlpool made frig, under kenmore name
set freezer temp warmer, this allows more air into the fridge compartment, its opposite from hoe=w they look! and a common service call issue thats nuisance related
Aug 23, 2009 | Kenmore Refrigerators
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
Frig not getting cold
See if the coils are blocked with ice. Fridge gets cold air from freezer, ice would prevent this thus a warm fridge.
May 10, 2009 | Refrigerators
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
179 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
