Question about Bulldog Remote Stater w/Keyless Entry and 2 remotes
My keyless remote entry for my 2001 mitsubishi galant stopped working so i replaced the battery and it still doesnt work. its a v6 if that matters
  • Anonymous Mar 26, 2014
    i HAVE A REPLACEMENT ELVATOC APS2K4SAW REMOTE AND I NEED TO REPROGRAM IT TO WORK
  • 22 Answers
Inside your remote is a small flat driver slot this is a tuner ,start inside the car and gradually turn the dial and try the remote , this will tune the remote.,Does the light on your remote flash when you push the button?
Posted on Apr 21, 2009
Is there a way to reset keyless entry for 04 endeavor?
Search Results
    2004 Mitsubishi Endeavor Key Fob Remote Programming ...
    blog.keylessentryremotefob.com/.../04/2004-mitsubishi-endeavor-key-fo...
    Apr 25, 2013 - 2004 Mitsubishi Endeavor Key Fob Remote Programming Instructions ... you might have visit us at Keylessentryremotefob.com You can also ...
    Mitsubishi - Free Keyless Remote Fob Entry programming .
    How To Replace Mitsubishi Endeavor Key Fob Battery 2004 ...
    ? 2:04
    www.youtube.com/watch?v=yeQRdre7O0Q
    Oct 31, 2014 - Uploaded by Keyless Entry Remote Inc
    ... will show you How To Replace Mitsubishi Endeavor Key Fob Battery 2004 2005 To Order This Remote ...
Nov 01, 2015 | Cars & Trucks
Remote keyless entry doesn't work
try looking for a fuse relay for the remote central locking in the fuse box
Oct 10, 2012 | 2001 Oldsmobile Alero
2001 mustang keyless entry not working properly what do I do
You did it like this ?
Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
  1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
  1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
  1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Jan 15, 2018 | 2001 Ford Mustang
Does the 2001 eclipse syper come with a keyless entry key
It depends on what version you have. My 2001 Spyder GT came with 2. Unfortunatly they tie in with the radio and anti theft system and when the battery dies in the little stick remote (doesnt take long for this to happen) you have to get the codes off the radio, call mitsubishi, and get the exact right codes to make them work again
Oct 13, 2010 | 2001 Mitsubishi Eclipse Spyder
Keyless entry has stopped working. Battery is replaced but still no remote operation of the doors or trunk.
The keyless entry matches to the module for it that is mounted under the dash. It may have gone bad since your remote will not function. Of course it could be your remote as well that went bad
Jan 20, 2010 | 2001 Ford Taurus
My battery went dead on my 2001 galant. I
the stereo may have connection with your anti theft device, drive your car to the dealer and they can reset the device for you at a minimal charge. this should resolve these issues. Good luck
Nov 20, 2009 | 2001 Mitsubishi Eclipse
2001 Chevy cavalier Z24 keyless entry not working.
You should have it scaned to see if you have any codes. It has a RCDLR (remote control door lock reciever) this is the module that recieves the signal from the fobs. If it has a problem then the system will not work. If it has to be replaced then a dealer will have to program it for you. Good Luck
May 25, 2009 | 2001 Chevrolet Cavalier
Remote works but something else may be wrong with computer/fuse?
it could be a fuse or a relay, the system probably has both you should check them and replace if bad. if they are good your keyless entry receiver may be bad.
Mar 20, 2009 | 2001 Mitsubishi Galant
03 Galant - Door locks
looks like the battery. how old is the battery?
Jul 03, 2008 | 2003 Mitsubishi Galant
Bulldog Remote Stater w/Keyless Entry and 2 remotes Logo
335 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
