Question about Verizon Communications LG enV Cell Phone - Silver
Wont charge my lg env wont charge when i put in the charger, only will it work if i push an hold it in what can i do??
I had the same problem. It would only charge if I hung it from the charging cable. I went to Verizon and bought a new charger. It works fine now except that I can't talk when the charger is in... no one can hear me and I can't hear them. But at least it charges...
Posted on Apr 30, 2009
  • 3 Answers
Your charging port is loosely connected to *********** board. You need to go to a repair shop and get it fixed.
Posted on Apr 18, 2009
My LG enV will not charge. The actual part that you put the charger in wobbles and is unstable. I do not believe that there is anything wrong with the charger. I have tried moving it around to find a...
The charging port has broken off the main circuit board.
You will need to have it repaired by your service provider.
There is no other way to charge it.
Thanks!
Aug 04, 2011 | LG enV VX9900 Cellular Phone
Env Phone wont start up
Well, in my experinece, one of two issues. You said your charger port is bad. Thats not good. It will give you enough juice to barely turn the phone on and it goes out. MOST phones will do that. IF you know your charger port works, try a new battery, if it doesnt you have to get the charger port fixed as it will just constantly act as if the phone is dead, even if you put a new battery in it, it will blink on, touch a button eats up the battery bars and dies. craigslist.org usually has alot of cell phone repair people on it. depends on your community.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
How do you dismantle the end of the charger?
Absolutely not. You must use the LG charger, or you might get an improper amount of current into the phone and toast it.
Jan 04, 2009 | LG enV VX9900 Cellular Phone
Ive put my phone on the charge, but it isnt charging, whats the problem? my env cell phone isnt charging when i put it in the charger
Your port could be messed up or it could be the charger. Take it in to verizon and they will look at it for free.
Dec 15, 2008 | LG enV VX9900 Cellular Phone
My EnV doesn't charge!
same thing happened with my friend, its a minor bug in the env, call 18009220204 (customer service) and tell them your problem, they should be more than happy to help you. they gave her a brand new phone free of charge. hope this helpeddddd;)
Aug 10, 2008 | LG enV VX9900 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
Apr 18, 2008 | LG enV VX9900 Cellular Phone
Lg env
it's so frustrating!
Apr 11, 2008 | LG enV VX9900 Cellular Phone
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
Env help plz
The reason the phone won't charge is because the internal power port pins are broken off of their solder joints to the main board inside the phone. Wiggling it helps at first because the pins can still touch their connection points but after a short time that will cease to help. Google "cell phone repair". It usually cost around $50 to get it fixed with a new power port installed. Turn-around is usually 2-3 days.
Mar 05, 2008 | LG enV VX9900 Cellular Phone
Verizon Communications LG enV Cell Phone - Silver Logo
269 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
