Question about Sony Ericsson K750i Cellular Phone
Water Sink my SE K750i sinks in salt water on yesterday but it is working properly except my memory card slot. plz help me out
Took it to a technician and ask him to clean the circuitry well.
Posted on Sep 18, 2007
Odour from only kitchen sink No food trapped plumber says pipes &vent syst in proper work order plumb is stumped 6 mos ago same thing happen pipes & trap under sink were changed house is 3 yr old
Presuming that the proper traps are installed, your issue may be related to flow. Sometimes, a run that is too steep causes so much flow that the water gets removed from the sink p-trap and will remove water from there.
To test, pour a some water down the sink, the next time that you smell sewer gasses. If that stops it, investigate why the water is being drawn away. You might consider an additional air vent, as a diagnostic tool.
Mar 09, 2015 | Home
Bibliography on does floating objects float better in salt or fresh water
Salt water has a higher density than pure water, so objects sink less in salt water.
Dec 06, 2013 | Computers & Internet
My monitor worked yesterday. I rebooted and the lower right power light started to blink. Looks like it is going to boot up, but the it starts blinking the word "ANALOG" + " DIGITAL",...
First check the processor fan is working if working remove the memory from the slot clean with a clean cloth and rub the conector with a erasor dont use any metel or any other thing insert the memory and see if the lock is locked on to memory properly still not working change the memory sutable for the memory slot still not working removce the processor heatsink and the processor clean the surface and apply athin layer of heat sink compound and fix back the processor if still not working change the processor if still not working use an addon graphics card and check for display
Oct 27, 2011 | Computers & Internet
We have a bosch tankless water heater in a 1600 sq ft works great except in one faucet (the spare bathroom sink)...sometimes the hot water comes out, sometimes it doesnt, sometimes it takes...
Since you have hot water at all the other fixtures, the problem lies in the sink, not the water heater. It could be that the sink is farther away from the water heater than the other fixtures. It would take longer to get hot water.
Aug 29, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
I dropped my samsung in my sink and i picked it up and took out the battery and let it dry and about 30 mins after i put the battery back in and up comes a blank white screen and it keeps vibrating how can...
Once a phone has been water damaged it will never work properly again. Water - even fresh water - contains salt. And, salt is an excellent conductor of electricity. When the water evaporates, salt deposits still remain. This causes the phone's electronics to short circuit causing a variety of problems.
The cost to repair the phone will far outweigh the cost to replace it. Repairing it does not mean that it will continue to work properly.
My advice is to sell the phone on eBay for parts. Let the buyer know it has suffered water damage. And, replace it with a new phone. You'll be much happier in the long run.
Feb 16, 2011 | Samsung SCH-U450 Cell Phone
Hi! I have Asus m2n-vm hdmi motherboard, about month ago i've got problem: if computer works more than 12 hours, it freezes and works normally just after few hours "rest". Also, after shutdown...
Hi lvadim1993,
In other word your PC works intermittently. Here is what you have to do. Check and remove the processor cooling fan and heat sink clean the cooling fan and heat sink. If you have a thermal compound remove the old thermal compound and put a little amount at the center of the heat sink. Reinstall it back the processor cooling fan and heat sink and make sure It install properly even and snag tight. re plug in the cooling fan connector to the motherboard. If you have a video card remove and clean the video card connector and the cooling fan and heat sink with air blower same also to the memory card. Use the air blower to clean the motherboard and the entire internal of the PC. Reinstall the video card and the memory card and make sure that they are install properly. replug in the video cable and the pc power cord and turn on the PC. this will work. the computer is just over heating. I hope that this information will help you solve the problem.
Jan 05, 2011 | Computers & Internet
The water softner is now filling up with water also the is water in the the overflow its sits in
The softener is not drawing brine during the regeneration cycle. The eductor assembly may be plugged or you may have a bad seal internally. It will keep filling the salt tank if the float assembly is not working properly also causing the salt tank to overflow.
Dec 28, 2010 | Culligan Under Sink Water Filter
Some water sits in the bottom and does not drain completely. Don't know if the drain inside the sink was not properly installed or if the sink is designed that way.
this is not supposed to happen, either drain not installed properly or drain is clogged. suggest trying drain cleaner first if sink has been in for a period of time. if sink is recently installed call whoever installed and have them fix the drain
Oct 30, 2009 | Pegasus Technologies Pegasus Clear Round...
My aqua starr 2700 is not working properly
First of all what kind of flow rates are you running? Low flow fixtures? Also when you installed it did you have your gas pressures checked? This unit should have no less than 4"WC at all times.
If its gassed properly, and not throwing any error codes, Then the water should be no issues.
Jan 17, 2009 | Bosch & Tankless LP Hot Water Heater
Sony Ericsson K750i Cellular Phone Logo
66 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
