Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Error Code 13 Washer won't drain
Hi I have a Bosch Nexxt 300 Series Washer. It keeps coming up with an E:13 error code and won't drain. Please help.
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
Is there a way to reset the computer my bosch 300 nexxt series washer?
turn off THE POWER by c. breaker, wait by 45 seconds, and turn ON again and try it.
God bless you
Jul 10, 2013 | Bosch Nexxt 300 Series WFMC2201UC
E04 error code, washer wont drain, water left in tub on a Bosch Nexxt 300 series
http://applianceguru.com/attachment.php?id=2463
Make sure you click helped, if helped that is.
Apr 12, 2013 | Bosch Washing Machines
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Bosch E13 error on washer - shows e-13 and door will not open.
Hello & Welcome to FixYa
E13 error in your Bosch WFMC washer is a drain error and is displayed when the drain time exceeds & the washer is unable to drain so the door won't open sometimes when this error is displayed. You will have to clean the drain trap in the bottom right hand corner. You can stick a straighten paper clip in the access panel located inside the front bottom panel through the whole and then turn the access panel counter clockwise to unscrew the plastic drain cap behind it. After everything is cleaned and the error returns then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Error code E:13 on my 500 plus series washer
The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
Thank you !!
May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Im getting an error e 13 message and the door will not unlock
error code = bad pump? or just a clogged screen /kinked drain hose?
E:13Er:13 test #P:15Drain pump time exceeded,Faulty drain pump, wire harness, hose
Apr 26, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Getting E:13 error on Nexxt 300 series washer
Try putting the washer on COLD and run "TWO" cycles. It must be on COLD. There is a chance there is too much soap or fabric softener in the washer. It may also help to clean the fabric softener tray where you add the softener.
Nov 22, 2009 | Bosch Nexxt 300 Series WFMC2201UC
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
4,741 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
