Restricted channels cannot figure out how to reset to factory settings
I just bought a Flat screen tv, model # 27ST6210/27 and it has restricted channels. It didnt'come with a remote control so I bought one online from the manufacturer. It doesnt' seem to any options to reset the tv to factory defaults or lift the restricted channels. Please help!
  • 451 Answers
Pressing the menu button should bring up options to adjust the color ,tint,etc. look for antennae options or parental control options to lift the restricted channels. hope this helps.
Bobalix
Posted on Apr 18, 2009
  • Alan Welsh
    Alan Welsh Dec 13, 2014
    its so out of wack i cant even see the menu
HOW TO GET UNLOCK CODE ?UNLOCK TV TOSHIBA
"If you cannot remember your PIN code
While the PIN code entering screen is displayed, press [RECALL] four times within five seconds. The PIN code will be cleared and you can enter a new PIN code."
Or you can trye this:
Step3Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Aug 07, 2014 | Toshiba REGZA Televison & Video
NEED CODE TO PROGAM TOSHIBA TV
Hi
You can trye this:
Reset toshiba tv password
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Jun 26, 2013 | Toshiba Regza 32El833G 32 in. LCD TV
Unlock tv menu
May 15, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
553SV Vizio TVand forgot the passcode. Anyway to retrieve it ? Or reset to factory settings
System Info
Display the technical information including model name, version and
revision of firmware, source type, and resolution.
Reset TV Settings
Return all Picture and Audio settings to factory default. A screen will come
up to confirm your selection or to cancel it. Press Left or Right Navigation
buttons to make the selection, and then press OK to accept it.
Note: This does NOT reset the Parental Control Password.
Clear Memory (Factory Default)
Use this function to reset the TV to the default factory settings. The screen
will display a message to confirm that you want to reset the values to
factory settings. Press ? or ? to make the selection, and then press OK to
accept it.
Guided Setup
Use this function to return to the Initial Setup menu. Use this function if you
want to have a guided setup when you move your TV. Refer to Chapter 3 for more information.
Note: Previously scanned channels will be removed.
Aug 16, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Factory reset was reset---now we have a no signal on the screen
Please go to tuning menu and select Auto Scan/ Auto Tuning to tune all available channels to store in tv memory.
Factory reset actually delete all data/ settings in memory chip and set tv as it was in-box.
Thanks.
Jun 13, 2010 | Olevia 237T 37 in. LCD TV
When I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
Mar 22, 2010 | Toshiba 22LV505 22 in. LCD TV
We just bought a used RCA TV (RCA 14F514T TruFlat)and the parental control is on it so that we can not get ANY channels and we do not have the password. ALL channels are being blocked at this time even...
Yes ask you parents!
Call the distributor of the RCA and provide the model number and proof of age and they will help you reset it to factory settings
Aug 17, 2009 | Televison & Video
Hi. I bought a new Samsung LCD Flat Panel TV, model LN52A630. I started playing with different settings and completely messed up, and i cannot set it back. Is there an option that i can use that resets all...
Most TVs have both a consumer menu system and a service menu system. Assuming you stayed in the consumer menus, there maybe a reset or defaults selection. Look around. If you don't find it, use google to locate a downloadable manual for your specific model. An occasional TV resets to default settings if you unplug it for 48 hours. Many have resets in the set menu when you program channels, parental control and time.
Dec 12, 2008 | Televison & Video
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
Electro Med Services...
