Question about Maytag MAH6700AWW Neptune Front-Load Washer
MAH4000AWW Bearing Noise When Spinning
Do you know if I order the seal kit Part #12002022, will I get the bearing also? It looks like from the parts diagrams on various sites that unless the bearing is in this kit, you have to buy the whole outer drum ($500) to get this part. Thanks in advance for your help.
  • chrish9 May 23, 2009
    When the washer goes into the spin cycle a clicking noise begins and the washer will not compensate for the load imbalance.
  • 58 Answers
12002022 is a seal kit only. The outer tub replacement is the correct fix, The part number for your unit is 22002907 and crosses over to 22004465. BTW. the replacement tub includes the seal kit and for the price I usually change the spinner assy at the same time..There are two part numbers for that.. It depends on your washer series which is determined by the first 2 numbers of your serial number... Hope this helps... Bill
Posted on May 18, 2009
  • jeff hartman Jun 05, 2011
    See Neptune Bearing for your replacement Maytag Neptune front loader bearings and 12002022 seal kit. Plus, you can rent a special tool kit designed just for replacing your Neptune bearings!
Whirlpool cabrio started making a loud noise when spinning. I've replaced the suspension springs before. Is that all I need to order? It's been a while.
Sounds like the bearings are toast. These machines have a poor seal in the tub which allows water to penetrate the bearings, drying/rusting them out. Go on "youtube" and search your problem. I use a 2"X4" and a jack on the center shaft to lift the drum out. Bearing tool and shaft/bearing, seal kit is approx. $150. Should take you approx. 4 hrs. if you're handy.
Nov 28, 2016 | Whirlpool Washing Machines
Loud Bearing Noise During Spin Cycle- MAH4000AWW
I don't know these front loaders so well but, here's a couple of things to look for.
1) If belt driven, look for the spring loaded tensioner. Once tension is released, check the pully & see if it has excessive play.
2) Check the gasket on front panel & see if drum has rubbed thru it in order to make metal to metal contact.
3) There is alot of pressure on that rear bearing...make sure it's not egg shaped or scored on the inside.
If all else fails, shotgun it (in other words, replace those moving parts you suspect:)
Nov 15, 2013 | Maytag Washing Machines
Spin cycle makes jet airplane takeoff noise. assume main bearing on spining tub is out. What part replaces this bearing? Diagrams do not mention bearing!
Bearings do exist but need a special puller to remove. If techs i n your area have it part numbers are 22002934 , 22003441 also needed is spacer 22002935 and seal kit 12002022 or else you need to order the whole outer basket
Jun 04, 2011 | Maytag Neptune MAH6500A Front Load Washer
I have a neptune mah4000awq washing machine and it started making a loud noise when on the spin cycle. Is this a bearing problem, belt problem. thanks for any suggestions.
Jun 04, 2011 | Maytag Neptune MAH5500B Front Load Washer
Loud noise on spin cycle only clothes dry good
Sounds like your bearings and seal need replaced... See Neptune Bearing for information on the Maytag Neptune bearing and 12002022 seal kit. You can also rent a special tool kit that includes the bearings, 12002022 seal kit, bearing spacer, step by step DVD, etc.
I would not run neptune with bad bearings too prevent more damage to the Neptune spinner support, Motor drive system...
I hope this helps you...
Feb 01, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
Need to know part #'s for honda atv rear wheel, bearings and seals. part# 42650-hm4-85.
Most older Honda atv's use a 6007 rear bearing (96150-60070-10) However Parts Unlimited and Dennis Kirk sell rear wheel bearing kits with seals that have everything you need to do the job. The kit typically sells for about the price of one Honda OEM bearing and is shipped right to your door(Dennis Kirk). If you want to look up the part numbers go to babbittsonline.com and use there microfiche. They have reasonable prices if you want to place an order.
Jun 30, 2010 | 1986 Honda XL 125 R
While spinning makes to much noise sounds like a train
This sound is an indication that the main bearing is failing, you will need a seal kit and bearing. It would be good to replace the Thrust bearing while in there too. Parts will run about $120.00 It is a pretty big job so to have an expert out and make the repair you are looking at about $175.00 labor. If the transmission were also bad which is a possibility if it is 10 years old or so you can add about $225.00 to the job.
Sorry to be the bearer of bad news here
Apr 19, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Looking for replacement bearings for the outer tub to inner tub on our Maytag FAV6800AWW, S/N 13389034ET. Don't want to replace the whole outer tub assy.
It sounds like you may have to replace the Outer Tub to replace the Outer Tub bearing .....ain't that just peachy.....good job Maytag design team.
If you are the original owner I would press Maytag hard to replace the Outer Tub based on the Outer tub Bearing failure. Their warranty states third thru tenth year Drive Motor, Outer Tub and Sealed Transmission. I’m sure you will need to have a certified Maytag repair service tech certify the failure and fix action required. Why should an Outer Tub bearing replacement cost you $430. Another poor design issue of this machine.
Sep 25, 2009 | Maytag Neptune FAV6800AW Top Load Washer
LG Washer makes LOUD noise when spinning
The main seal is leaking on the drum bearing hence the splatter of soap softened grease The water from the drum is coming through the seal and into the bearing and this is washing the bearing clean of grease. No option than to get it replaced with a new drum bearing kit , Sorry !!
Jun 04, 2009 | LG Washing Machines
Grease spots on clothes
Your drum support bracket grease shaft seal (which will require a new Lip Seal Kit #12002022) is dead and potentialy the two shaft bearing are at risk. Parts cost retail approx. $100 or so. Labor, Lookout...
I'm fighting this issue for the second time.......
Bill B.
May 20, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
777 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
