Rear plug in both do not power up,dvd player,monter will not work,fan is very loud
Onkyo 989 version 2 ... monter will noy come on,plug in the back do not work,to power dvd player,fan noise super loud...
  • smokeyhowell Apr 18, 2009
    I dusted the unit,no change,the fuse on onkyo,can I buy it at radio shack..Still no power to the 2 back ports for dvd player to hook up for power?
    Brigadier General:
  • 3,614 Answers
this cn be a dust or dirty fan causing the loud noise. better do cleaning first the unit before turning it on or before you use it.
micro
Posted on Apr 18, 2009
  • micromaster
    micromaster Apr 18, 2009
    if it is the fuse , you can get the part on radio shock. or in any local electronics shop on your area.
Just purchased a Panasonic DMT-350 with analog 7.1 out and hooked up to my Onkyo 989 but tried everything and i mean everything to get my rear surround to play but no luck....pleeeeeease help me.
Hi.
Connect the Panasonic to one of the AV inputs on the Onkyo. Use red white and yellow AV cables. Connect the output from the Panasonic to one of the five AV video inputs on the Onkyo (or use the DVD dedicated input in the Onkyo backpanel). I indicated this option using red arrows. You can use any of the AV inputs or the DVD input at the bottom. Just ensure you do not connect to an output at the back of the Onkyo.
Alternatively use component cables and optical audio input, as indicated using the blue arrows in picture below. Select source and listen surround from the Onkyo.
There are more options. In some case you may decide to connect the DVD video output to TV and the audio to the Onkyo.
Here a manual for the TX DS989.
Here the backpanel:
Dec 26, 2010 | Onkyo TX-DS989 Receiver
Tip
Onkyo DR90 Manual Download
Onkyo DR90 DVD Receiver Manual Download
Have you misplaced your Onkyo DR90 DVD Receiver Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo DR90 DVD Receiver Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Onkyo Universal Remote Codes here.
on Apr 20, 2010 | Onkyo DR90
My onkyo dv-cp704 powers on but frrezes after
HI...
A problem like that will need tech service.
Check the onkyo consumer site for service people
Dec 05, 2008 | Onkyo DV-CP704 DVD Player
Play all region dvds
Multi-Region Hack:
Press the Open button on your Onkyo DVD-player to Open the drive tray.
Using the remote press 9, 9, 9 and 9 on your remote control.
Press the 1 button on your remote control for region 1, 2 for region 2, and so on, or 9 for multi-region.
Press OK and the tray will close.
Reset the unit by powering Off and then back On again.
Jan 14, 2008 | Onkyo DV-CP704 DVD Player
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
DVDs presumed stuck and the player won't eject
Hi, If you feel comfortable opening the unit, then you may remove the top cover normally held by 2 - 4 screws. The tray should be visible and most units have a locking bar right at the center to hold the discs down. Removing this (2 screws normally, 1 at each end of the bar) would expose fully the tray with the 2 discs on top. Remove the discs and put the locking bar back with the screws. You can test the unit without the top cover. Please be reminded about safety precaution when working with active/live units and laser equipment. Power it up and check if the "mech err" still shows. If not you're set to cover it up, otherwise, your probably better off seeking the services of a qualified technician. This is a generic method which normally should apply to most CD/DVD units. Good luck and kind regards.
Aug 19, 2007 | Onkyo DV-CP702 DVD Player
Low volume while on both DVD and watching Satellite channels.
call onkyo product support 8002251946 option 6...since they did the mod for u...they should b able to take care of this at a minimal charge if any. alan audio video designs 3822 s. staples cc,tx 3618577236
Apr 30, 2007 | Onkyo TX-DS989 Receiver
41 people viewed this question
 Grubhead
Grubhead
