Question about Nikon COOLPIX L4 Digital Camera
Can't see anything but black
When I turn on my camera all I see on my display no matter inside or out is black. Batteries are new. There is something red flasshing on the right bottom corner that kind of looks like a clock reading 9:00. Can't figure it out.
  • PabloB Dec 21, 2007
    My screen freeze is a little different - the left third is two shades of black and the remainder looks like part of a sky shot with a tree branch. I was just using my internal memory and pushed it to the limit. Sometimes, I can see part of the menu but never well enoughg to try formatting or deleting. When I hook up to computer, the camera says all the pictures are write protected.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Very common fault with this model. It is the CCD sensor that is faulty . Inquire with Nikon if their existing policy of repairing cameras with CCD sensor faults free of charge covers this model I believe it does ( also see attached pic of sensor from a Canon camera which looks and performs like yours )
Posted on Sep 18, 2007
SOURCE:
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
My screen is also black and will not do anything. Checked batts there good nothing done to camrea to break it was not dropped or damaged in any way
If the display is black in all function modes then your LCD screen is likely dead. If you can still use the display as a viewfinder and/or to review pictures, chances are that your lens is stuck in the closed position. There is no safe DIY fix for either condition -- the camera will require professional repair. But, before you panic or spend any money on repairs, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 14, 2009 | Kodak EasyShare Z612 Digital Camera
I have casio exilim ex-z50. It worked fine the last time i used it. I went to use it yesterday and when i powered it on it asked for a date & time reset. after i reset the time it turned off and would...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 07, 2009 | Casio Exilim EX-Z50 Digital Camera
Camera won't stay on in camera mode but does in display mode
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 26, 2009 | Casio EXILIM Card EX-S770 Digital Camera
With batteries inserted, I turn top dial from off to auto. The green light comes on and is instantly replaced by a red light. The menu display screen remains black when pushed. I'm using new batteries
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Sep 26, 2009 | Kodak Cameras
LCD is black with camera on, new batteries, etc.
CCD is dead. Very common problem.
Needs new CCD.
Apr 21, 2009 | Canon PowerShot A75 Digital Camera
When I put brand new batteries, it says "Change Batteries"
Use a Q-tip with alcohol to clean all the batter contacts (battery cover and inside the battery compartment), and a small hook into the compartment to pull up the contacts a little bit up. The idea is to make the batteries connect properly.
Use NiMh rechargeable batteries or Alkaline batteries, don’t use other Dry batteries, which are not designed for digital camera.
Apr 10, 2009 | Canon PowerShot S1 IS Digital Camera
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
How cold is too cold for the S730?
Take the camera inside and let it warm up to room temperature. Get another set of brand new batteries. But first take out the batteries and let it sit for an hour. Without any power it can reset itself. The mini cpu inside is thinking its too cold and won't let it come on. After the one hour of sitting, put the new batteries in it and try to power it up. Cold weather can kill a brand new set of batteries in a matter of minutes. You should try not using your camera when its below freezing.
Jan 09, 2009 | Samsung Digimax S730 Digital Camera
Zoom Error
In order to fix this try turning your camera on,(With new batteries) and while its on push the lens back in. Then turn it back on. Hope this helps.
May 25, 2006 | Fuji FinePix A205 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
67 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
