Question about Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe
Iomega Minimax HD, no power but lead light is on. Working fine, then I turned it on today & nothing, no fan, no light but the power lead green light comes on. How do I know if its the HD or the power lead without buying a new one?
  • miamber Apr 19, 2009
    I appreciate your comments but I don't think you get the problem, also I have a mac mini as my main computer the minimax is a back-up drive.
    Surely to get this hard drive to function as a slave or partition it needs a power supply?
  • chiegl1967 Apr 25, 2009
    Same deal.  I was cleaning my desk, when to turn the MiniMax on and the blue light never came on, no fan, same exact issue.
  • 45 Answers
In your situation I would :
open the minimax enclosure, and take the hd out, (just open the enclosure, not the hd itself), and then open your desktop and connect this hd as slave (I am guessing you have a desktop with IDE hd and that the minimax has an IDE hard drive in it.... or both your desktop and the minimax has SATA hard drives) and then when you turn on your computer you should be able to see your second hd as a partition and be able to see the info in there, yet if windows does not recognize it, that means your hd is useless., yet remember you have to change the pin on your external hd to be slave or auto detect, if you let it as master your computer won't boot, bout do not worry, after you unpluges the hd from your desktop everything will be normal
p.d.
shutdown and unpluged the power cord from your desktop when adding/removing the hd.
Posted on Apr 19, 2009
  • Israel Soto Apr 19, 2009
    Well, when you connect it as Slave you do not need an external power supply, the hd should be connected inside the computer, to the IDE bus, and the power supply come from the PC power source.
    And doing this you will know if the hd still works, and you will access the data in it.
    But since you are using mac, you do not have ide, because it is power PC infrastructure. Sorry about that, I do not work with power PC
My hard drive will not turn on, plugs are all in green light flashes in the back, but nothing else, no fan, no light on the top of hd nothing but a flshing green light in the rear of the casing
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 23, 2011 | HP Computers & Internet
I have an iomega minimax device that I cannot seem to connect to my imac. when i plug the device in nothing happens on the desktop.
try getting a new power cord from iomega, If that doesn;t work, the drive is probably corrupted. They are under a year warranty. You ship yours to them and they will send you a new one. Try the free chat on Iomega
Jan 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega Screenplay buzzing no Disc wont bring up Folders
I have a Screen Play HD. It was working fine until today when suddenly all my computers can't detect it. I tried a different external disk, it worked fine.
Jul 06, 2009 | Iomega ScreenPlay
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Iomega mini max external HD slowing things down
the hd external iomega 500 gb minimax have a litle noice and don't work dont conect whit my computer.
Mar 06, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega harddrive minimax 250 GB is dead
is it usb ad has it got screws in the houseing if so unscrews the the thing and then see if it has got IDE ribbon cable or scsci connection if it has got IDE Connection then check power cable connection to hdd if it's loose then use small open ended screwdrier and close each end slightly and try power to hdd if stillno power then open pc case and connect to pc power cable and see power up via pc if works buy a box that houses Ide harddrives in the country you live in it means that the country you got it from has got a lower vaultage than yours. yours warewolf ps any more info needed contact me on warewolf2001@hotmail.com in box subject please put pcrepair- your problem after the - replys will be sent as soon as I can
Jan 10, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
Open Questions:
See all Iomega MiniMax Desktop - Hard drive - 500 GB - Questions
Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe Logo
1,190 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
