Question about Lands Phones
Sync music wont work nieathere will usb drag and drop won t work either
I cant load music on my motorola w233. i have a mico sd card in it. i am runing visa home pre. any sugg
  • Carl Navarro
    Carl Navarro May 11, 2010
    I hope English is your SECOND language, because it needs help.
    In my Motorola, I put the SD card in the phone, formatted it, which created the sub-folders, then put it in my PC and dragged the MP3 files to the My Music folder.
I also have the W233. Love the 9 hour battery- great for music. I was having problems getting music to load but I just figured it out and it now works. 1) make sure usb cable is for data and not just charging. 2) make sure the music files are a supported file type such as MP3, because WML is NOT a supported file type for this phone (I had to change my Windows Media Player Rip options so that it was Riping to my computer as MP3, the default is WML. Then I had to delete and re-rip music as MP3 that I wanted on my phone). 3) also, the manual for the W233 says it only supports upto 2GB micro sd card, and only guarantees San-Disk but I used a 2GB Lexar and it works.
Hope that helps anyone
Posted on Apr 27, 2009
Sync itunes
Launch iTunes.
Connect your media player with SanDisk memory card installed to your computer through its USB adapter.
Wait for the player's device icon to appear in the iTunes Source pane.
Drag and drop music titles from the library pane directly onto the device icon.
The music will sync onto the player's SD storage.
hope this helps
Sep 17, 2012 | SanDisk Cruzer Glide - USB flash drive -...
How do I sync music to my Droid from Windows Media playlist? I've ripped and burned but it won't allow the sync from that site, Thanks
Hmm, try this: Either use or buy (for around $2.00 from ebay sellers) a Data cable for the Droid (standard mini-usb plug) and sync it like that.
Mar 11, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
When i try to download music from my laptop to the cliq it says the sd card is busy
1.) make sure the sd card is mounted after you plug in the USB cable. (pull down top bar and click on the USB notifier...)
2.) Open a window on the laptop that has your music.
3.) Open a window on the laptop that shows your cliq's sd card.
4.) Drag and drop the music files to the folder you want on the sd card
5.) when you are done copying, drag down the top bar again, but this time choose "turn off"... and you are good to go
Jan 12, 2010 | Motorola Mobility CLIQ Cell Phone
How do i load music into my new i856 by boost
according to motorola, this phone has bluetooth and micro SD card slot.
if you have computer with bluetooth, then you can pair the computer and phone and simply send music files wirelessly via bluetooth.
if you dont have bluetooth, then you can buy a cheap usb bluetooth adapter from ebay and have a bluetooth enabled computer, then follow above step.
if you have SD card slot on your computer then you can get a SD card to micro SD card slot adapter from ebay or elsewhere, where you can simply put music on then card from pc and then transfer the card to the phone.
here is the phone manual.for safety read the whole manual.
p.55 for music and p.79 for bluetooth instructions.
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i856/US-EN/_Documents/Static_Files/i856_UG__%20Boost_NNTN7815A_.pdf
Nov 06, 2009 | Motorola Mobility i850 Cellular Phone
I cant put music in my motorola cliq. i found the sd card on my computer but i cant drag and drop music files and i dont know where to put them. help!!!
Easy fix.
Connect the Cliq to your computer, and set it to be used as "USB Drive".
The SD Card will come up as a drive. Locate the Media folder, then Audio, and copy and paste all files there.
and you are done, your music player should automatically find the files.
Oct 24, 2009 | Motorola Mobility CLIQ Cell Phone
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
How to down load music to i880 from the my pc
Open the folder and put it in the audio folder or just use the usb memory card adapter and drag and drop
Dec 29, 2008 | Motorola Mobility i880 Cellular Phone
Samsung gravity music player help
hello all
i recently got the samsung gravity as well and had a 4gb card for it and got the same problem.... from what i have found its not the size of the card its that the phone does not support the (HC - high capicity) micro sd card. I went down and bought a regular 2gb microsd card and popped it in and it works fine. also all you have to do to put music on the card is drag(from your pc) and drop into the music folder(on the sd card). hope this helps. have a great day!!
Dec 27, 2008 | Cell Phones
Cant transfer music file to my lg ku990 via usb from pc to phone
Instead of loading the music manager, click on file in the LG Suite box, and then click 'content'. This will connect without a problem (at least it did for me, despite music manager not working), and then drag and drop music from your pc files, onto your phone. Hope this helps.
Jul 27, 2008 | LG KU990 Viewty
Cant download music
The songs need to be formatted for a sansa. Use Windows Media Player 11. Don't use Rhapsody, too many problems.
Load a CD into your computer, on the Toolbar of WMP11 click rip, After all songs are ripped, hook up your Sansa to the computer via USB cable, Click Sync. WMP11 will not only sync the sansa it will sync the micro card also. You have your choice where you want to put the music. Drag and drop the music in the box to the left where you synced your sansa and at the bottom of the box click Sync. All music will be synced to your sansa or card which ever one you chose. Understand, when the sansa starts up, the card syncs with the sansa, you don't have to do anything. Try this and let me know how it works.
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
Lands Phones Logo
299 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
