Kenmore 63942 Dryer
Problem for Kenmore 63942 Dryer
Kenmore Dryer will not heat
By b65j66j01 on Apr 18, 2009
Dryer stopped heating. Have used service instructions inside with multimeter...fuse looks ok, the hight limit thermostat shows good, and when I check the three resistances on the gas valve coil - terminals 1 to 2 read 1399 (1365 +/- 25 typ), terminals 1 to 3 573 (560 +/- 25) and terminals 4 to 5 read 1305 (supposed to be 1220 +/- 50. This made me think the coil was bad so I ordered a new one...but it reads the same. Does anyone know if the terminal 4/5 range is really 1270 max or if 1305 is ok. Next step - I think - is to order replacement machine control electronics ($170). Any other suggestions...help???
Comments:
Apr 18, 2009
- Don't see any reset button. Checked the voltage coming out of the control board to the thermal fuse (ok) then the high limit thermostat (ok) and then it goes to the valve controls. There are five wires...the black wire which looks to connect to the motor centrifugal switch per the wiring diagram...is not reading voltage. The other connections are all live. Any way I can post the wiring diagram? Keep in mind the dryer runs - everything seems to work but the heat. (Julie)
Solution #1
posted on Apr 18, 2009
Not Rated)
dlmcmasters
Rank: Guru
Rating: 90%, 384 votes
Does the limit switch have a reset button on it or is it an auto reset? Have you tried depressing the reset button on it if it is a manual reset? Have you checked your voltages to the gas valve, ignitor to make sure they are being called to come on? Trace your electrical connections from your electronics to these items. If they are not being told to come on, then you know it is the electronics. Also, have you checked the continuity of the door switch, and the ignite? These are all suggestions that must be ruled out before replacing parts.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 63942 Dryer
Questions and Unsolved Problems for Kenmore 63942 Dryer
Do you recommend Kenmore 63942 Dryer?
Answer
Answer
The dryer will start when the button is pushed but as soon as the button is released the dryer... (More)
Answer
how do you open the bottom to reset the dryer
Answer
Is there a reset button on a Kenmore Dryer model 76990800. The dryer won't start initially but I set... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , HI
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
