Question about Dryers
I replaced the igniter because it is not heating up didn't work what next ?
  • l_s_teach Apr 18, 2009
    Not finding the reset button .
  • 659 Answers
Check the limit switch that is located on the fire box. They usually have a reset button on them. They are about the size of a penny. Also, check the continuity of the door switch. These are common problems with dryers. You should have checked the continuity of the ignitor before replacing. Also, with a volt meter, test voltage to the ignitor to see if it is being "told" to come on.
Posted on Apr 18, 2009
  • Donni Steen Apr 18, 2009
    If it has a reset, which it can be an auto reset, it will be located between the two wires going to the limit switch.
1993 Mercury Sable won't stay running
Seems that the fault relates to heating, check if the fuel pressure is dropping when the engine heats up, allow the car to idle so as to confirm . Also this will indicate if there is failure of the ignition system, This can fault in the ignition , failure of the HT coils.
What is important is your observation to the case before any part is replaced.
Oct 29, 2011 | Cars & Trucks
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Dryer everything works, but no heat.
You didn't mention whether it was a gas or electric dryer, but either way it probably just isn't producing heat. If it's electric, it's most likely a defective heating element. If it's gas, the burner probably isn't igniting. On both there is usually some sort of thermal shut off switch that can also go bad and shut off the heat element or the burner.
Jul 15, 2011 | Dryers
GE JGBP33 gas oven will not light. Burners and brioler will light. When trying to ignite oven, igniter will not glow, and I see no change in voltage accross igniter contacts. What's next step to...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 27, 2011 | GE Ovens
I have a LG dryer (DLG5988B) with no heat, maybe the igniter is bad. What is the part needed, and can I replace the igniter myself.
First check the high limit switch to make sure it didn't trip. You will need a multi meter to check.
Jun 17, 2011 | LG Dryers
I tried turning the main oven on and it didn't heat up and had gas odor. Side oven and burners were working fine. Next day, tried again and it worked no problem. Next day, same issue.
heatman101
Apr 16, 2011 | Thermador PD486GEBS Stainless Steel Dual...
My oven does not flame up when the heating element heats up.what do i do next?
heatman101
Oct 04, 2010 | Frigidaire Kitchen Ranges
Kenmore elite gas dryer doesn't always heat or dry clothes
An intermittent heat problem is probably in the gas igniter circuit. I would first check the flame sensor next to the igniter for dust on the glass cover. If you have a trouble door, you can see if the igniter is working. Sometimes gas valve controls will fail. If you have to replace the whole control, check inside the plumbing for filters.
Apr 22, 2009 | Kenmore Dryers
Dryer is running but there is no heat
possible thermal fuse on back next to blower housing or flame sensor on side of burner ..short the wires on flame sensor together to ck
Nov 19, 2008 | Kenmore Dryers
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
