Question about Nikon Speedlight SB-800 TTL Flash
Using SB 800 flash Master with 2 SB 600 as slave
I have a digital camera with an SB 800 flash and two SB 600. I would like to have the three flashes lit up at the same time (the SB 800 as the Master and the two SB 600 as slave).
My question is: how do I set that up?
Frank
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Posted on Apr 23, 2009
  • kristinedaub Dec 31, 2010
    Are all three flashes supposed to fire at the same time? When I test my 800 the slaves flash later. And once I place the 800 onto my actual camera the master mode goes away. Are my camera (D100) and my flash (SB800) not compatible?
What the best flash for d80? s sb 800 & 900 compatible for it?
The best flash for YOUR D80 is the one that best suits YOUR needs. Both the SB-800 and SB-900 are compatible with the D80. So is the SB-600, which is lighter and smaller.
Jan 09, 2011 | Nikon D80 Digital Camera with 18-135mm...
NIKON SB800 IN SOFTBOX
Hello..
Sporadic off camera flashes triggered with pocket wizards will not be as obtrusive as you may think. IMP, It's just as obtrusive as the onslaught of small digi cam flashes that usually occur..Cheerss!!....
Jul 24, 2008 | Nikon Speedlight SB-800 TTL Flash
SB-600 flash suddenly dead. Found some early corrosion on the AA batteries. What happened? Repairable?
Hi degossman, Corrosion is sometimes a fix us users can do. Other times it must go in for repair. What happens is the corrosion may leak past the point we can see in to the internals of the housing eating out wiring.
Nikon digital 1-800-645-6689
Nov 30, 2010 | Nikon Speedlight SB-600 TTL Flash
What setting should the camera be on for an
That depends on the flash. If it's CLS-compatible (Nikon SB-400, SB-600, SB-800, and SB-900) you can use it in any exposure mode (except flash off, of course). The easiest flash mode is Auto-TTL, though some of the other modes will give you better control under certain situations.
If it's not CLS-compatible, then you'll have to take it off Auto-TTL. If the flash has a sensor, you can let the flash control itself (assuming it's at the same distance from the subject as the camera). Otherwise you'll have to go manual.
May 12, 2010 | Nikon D60 Digital Camera with 18-55mm lens
I have a new D3000 and a nikon SB-600 flash. I
From the Nikon site, do you have one of these flash units.
Support for the Nikon Creative Lighting System when using SB-900, SB-600, or SB-400 Speedlights, or the SU-800 Wireless Speedlight Commander
If so You set the flash mode to "comander" the pop up flash must be UP
This Video by Nikon shows how but you will have to read the manual to get a full description go to the flash section http://www.nikondigitutor.com/eng/d300s/index.html
Then look at them all :)
Jan 21, 2010 | Nikon D3000 Digital Camera
The flash is not in sync with my nikon d40 anymore. It fires first. Pictures come out dark. The camera itself takes great flash pictures
It sounds like you're trying to use the SB-600 off camera, as a slave flash. While the SB-600 does indeed have slave capability, the D40 does not have the ability to function as a commander. Thus, the SB-600 is being triggered by the D40's pre-flash.
As stated above, the D40 does not function in commander mode. You can mount an SB-800 or SB-900 flash unit, which will function as a commander as well as a flash. Or you can mount an SU-800 commander unit.
Alternatively, you can switch the D40 to manual flash mode so as to eliminiate the preflash. However, you will then have to calculate the proper exposure yourself.
Dec 31, 2009 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    I have just recently boughta Nikon D60 and currently own a Tamron 28-300 lens and a 90 macro lens. I think that I want to buy a strob after a workshop I went to this past weekend. I want to be able to...
    The SB-600 will probably do everything you want.
    One caution: To use flash off your D60 you're going to need either an external sync cord or a wireless controller. The SB-800 (and the current SB-900) can be used as a controller, the SB-600 can't. But the controller goes on the camera, so you'll end up needing two flashes.
    Oct 22, 2008 | Nikon Cameras
    Settings for sb-800 to control external sb-600
    set the SB-800 as the commander and SB-600 as the slave. Press and hold the mode button to open up the menu and select the options.
    Mar 25, 2008 | Nikon Speedlight SB-800 TTL Flash
    Sb-600 not beeping, images completely black (underexposed)
    Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
    I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
    Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-800 TTL Flash Logo
    769 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
