Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
Amp cuts off
I have a Alpine pdx1.1000 on 2 12" db drive platinum series. when the bass hits its cuts off. If I unplug one sub it doesnt cut off and both subs work fine when I plug them in one at a time. its when both are plugged in it cuts off and comes back on. It worked fine until tonight. thanks in advance
  • atom230 Dec 31, 2007
    i have 2 12" alpine type r subs and when i turn the volume up the amp cuts out and a red light turns on,on the amp. if i shut the car off turn it back on again it works fine for a bit then it happens again. i have aredy upgrader the wiring to 4 gadge to the amp and 12 gadge to the subs
  • hunds02 Oct 08, 2008
    I have a alpine pdx1.1000 amplifier powering one Orion HCCA 12.4. This sub is a DVC 4-ohm sub. When i wire it in parallel,( positives to positives and negatives to negatives) and turn it up, the four 20A fuses blow whenever it hits a loud and low freq. note. I really don't know why that happens, the PDX 1.1000 should be stable at 2 ohms but it looks like its not.. Right now i have it wired in series (8 ohm load), it sounds good but i want to have it work under 2 ohms. Any suggestions or tips???
Hey there. i have a PDX 1.1000 with 2 12" Type R Subs. I had the same problem for a long time. but i upgraded my power cable from 4 gauge to 0 gauge and put another earth from the battery to the chasis. the bass hits alot harder now and rarely cuts out. except now im having the problem of the 4 25 amp fuses blowing on the amp....
Posted on Jan 17, 2009
  • 631 Answers
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Posted on Sep 19, 2007
My DB Drive pd 1200.1 amp shuts off when the volume is raised. What is happening and what should I do?
The vibration from the bass is cutting off the amp. it is a loose wire causing this issue. you can also get a stabilizer that will stop the vibrations from causing this issue.
Feb 27, 2013 | DB Drive Platinum PD1200 Car Audio...
My subwoofer is cutting off. I replaced to fuse on the main power, and it works when I have the source on a very low volume level but when I turn the volume up, it cuts off. I have 1 alpine type R12 and a...
You are probably running the ohms too low for the amp and its drawing too much current. Consult your amp manual for proper load level capacity and you can wire it accordingly. More then likely its only 4ohm stable bridged and your running it at 2 or less depending on if your subs have single or dual voice coils. Try connecting one pos speaker terminal to the other speaker neg then run the left ofer pos on one speaker and the the left over neg directly to the amp (series) I will raise the ohms (amp makes less power) but should not cut off unless the subs ohm are still to low, if this is the case you need a sub with a higher ohm rating or an amp wiht a lower rating...
Nov 13, 2009 | Alpine SWR-1222D 12" Type-R Series...
I have a set of Alpine Type R 12 inch subs... I have a 1500 watt amp powering them but when I turn the music up, the bass cuts out. Where should I start looking for the problem?
ground is loose(most likely amp), battery running low, subs might be damaged? feel free to keep me in touch if problem occurs more after checking grounds and power source and subs. Also might need to re-tune your head unit and amp?
Jul 03, 2009 | Alpine Type-R SWR-1042D Car Subwoofer
Amp cutting out when bass hits
With an amp like that you can not pull enough power from you cars battery alone. That is why when it hits hard it drains the amps from your battery and you amplifier cuts out. The light on the amplifier most likely dims when the bass hits. You need to get a capacitor. They are easy to hook up on the main power wire. You can get one from or get a used one off Good luck
Jul 01, 2009 | Alphasonik PMA1000D Car Audio Amplifier
Bostom tweeter cutting out
get a new tweeter. really, if its starting to cut out, or static, then its prabably old and need a new 1
hope i was help :)
Apr 28, 2009 | Car Audio & Video
No light on Alpine MRP-M1000
Ok. Have you check the Ground and the Power connection.
Jan 25, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Dec 31, 2007 | DB Drive A460 Car Audio Amplifier
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
845 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
