Question about LG WD-3243RHD Front Load Washer / Dryer
Lp conversion for LG dryer
Can someone help with info on removing the top cover of an LG front loader dryer after the L bracket is removed ?
  • 1,543 Answers
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Posted on Apr 18, 2009
Removing panel to install conversion kit
Some panels can't be removed from the back but from the Top and Front only. Check the Front and the Top
Apr 12, 2013 | Sears Kenmore 6.0 cu. ft. Gas Dryer, White...
How do you remove the top on a LG WM2077CW front loader?
I can not remove the top cover of my LG WM-2277HW
can somebody tell me how to lift off the top cover. I already
removed the screws from the rear
Nov 09, 2009 | LG WM-2277HW Front Load Washer
I need access to gas valve in my Maytag mdg5500aww dryer
When I posted the question, I had not removed the front of the dryer. I thought the gas burner etc. had to be accessed from the back. As soon as I removed the front of the dryer I realized it was all up front and accessable. Conversion was straight forward from that point.
Jan 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
LG Dryer DLG7188RM LP conversion back to NG
Disconnect power. Open dryer door and remove 2 phillips screws near lint filter. Remove three phillips screws at very back of dryer top which go through an L shaped part into the back of the dryer. (the L shaped part remains attached to the dryer top) Push the dryer top back about 2 inches and lift off. Remove one screw at each top front corner holding front control panel on to dryer. Remove control panel by carefully releasing plastic tabs which are holding front control panel onto metal support. (Watch out for sharp edges !) You can unplug all electrical plugs, or just swing it up on top of the dryer. (careful not to scratch the plastic control panel) Remove the four phillip screws now assessable at the top of the dryer's front panel / door panel. Tilt forward, unplug door switch and drum light, and lift front panel off . Now set the panel aside. At this point, you may be able to continue with the conversion, but it is easier to do and see if you remove the drum.
To remove drum, Unplug the sensor wire at the bottom of the drum support and remove four phillips screws (going into sides of dryer) holding front drum support and lift up and remove front drum support. Reach in under the drum to unhook the belt. Take drum out.
Take two phillip screws out of flame spreader and push flame spreader back off brass orifice into the burner cone a bit to remove it. Unscrew brass orifice and replace with the Natural Gas orifice. Turn the brass slot headed regulator blocker screw on the front top of the gas valve all the way up. Reassemble.
Sounds complicated but it's not real bad.
A FixYa rating is expected with this much help. Thanks.
Nov 20, 2008 | LG DLG5932W Gas Dryer
How do you install an LP conversion kit on a Samsung dryer
kit comes with minimal instructions. you need to remove the burner which requires removal of the top panel, control panel and front panel. (see how do I remove front panel on samsung dryer for more details). It is fairly easy, maybe an hour the first time you have done it. Pay attention to all of the instructions re the burner, do not losen any of the gas tight fittings!
Jun 24, 2008 | Samsung Dryers
LG gas dryer to convert in propane
If you replaced the orifice on the gas valve, then you must screw down on the adjustment screw on top of the valve.  Use a flat screwdriver and screw down the pressure adjustment screw till it stops in the down position.  Then the valve is set for propane use.
May 05, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Lg 7188 gas dryer conversion to lp
How do you get the front off a LG gas dryer
May 02, 2008 | LG DLE5977 Electric Dryer
LG 6988 gas dryer conversion
you will need to get to the gas valve right front after the panel is off the orfice is in the end if the burner
Jan 25, 2008 | LG DLE0332 Gas Dryer
Lg conversion to lp
remove the top, and than the control panel, and than the front will come off to expose the gas burner on the bottom right side...
Oct 25, 2007 | LG DLE5977 Electric Dryer
LP gas conversion on an LG dryer
Mr. D, make sure you have a little time, you have to remove a few things. 1. Remove the 3 screws in back which hold the top on. Slide the top back and lift off. 2. Remove the two screws on each end of the control panel frame. (inside). Disconnect the control panel harness, pull up and foward, place aside. Remove the 4 screws on the top of the front cover, disconnect the harness for the door switch and it should pull foward. Now I believe you can get at the gas valve on the lower right. Make sure to reverse the limiter as well as putting on the new orfice. If you need any further help, e mail me at catriver1@gmail.com Will be home this evening. Catriver.
Mar 16, 2007 | LG DLG5988 Stainless Steel Gas Dryer
LG WD-3243RHD Front Load Washer / Dryer Logo
275 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
