Question about Echo Garden
My Echo power edge trimmer starts and idles fine. When I try to throttle up it begins to die out. I can get it to run at a slower speed, but to get it to maximum rev it dies. I replaced the spark plug, air filter, and gas filter.
I was having the same problem and stood there while the tech fixed it for me. I could have done it myself; honestly, nothing to be afraid of. Take the air cleaner off and then take the carburetor off and start taking it apart layer by layer (remove screws and take pictures with a digital camera of how to put it back). It is not complicated and it was a small piece of grass stuck where you never thought it could get that allowed a start but not full throttle.
Posted on Jun 05, 2009
Echo Trimmer starts but won't run
Replace the filter in the gas tank. Sounds like it is mostly plugged.
Jul 10, 2017 | Echo Garden
1996 mercedes c280 dies when put in drive
Engine stalls or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 15, 2012 | 1996 Mercedes-Benz C-Class
My echo stick edger starts fine , idles fine , when i start edging it dies. but starts right back up. replaced the gromet. didnt help.what do i check now?
If the fuel filter in the tank is part blocked this could happen, these engines need to run a little on the rich side when running free, the excess fuel is required once load is put on the engine, so try changing the fuel filter.
Jun 20, 2012 | Echo Garden
I have a TroyBilt trimmer Model TB25CS 2 cycle. I have replaced the carb mounting gaskets and rebuilt the Zama Carb. It idles fine, but when I give it full throttle it just dies. There is a white and...
first remove your muffler and check to see if screen is plugged in exhaust..this will cause it not to rev. Also if you rebuilt your carb you neglected to pull your jets out and flush them out, pull both caps off adj screws with small screwdriver and try to adj "H" turn counterclockwise 1/8to 1/4 turn and see if it improves any if so keep turning till rpms start to slow back down then slowly turn back clockwise just till on edge of rpms speeding back up ,also did you change your fuel filter? hope this helps you!
Apr 14, 2011 | Troy Garden
I have a 452 echo. lost the manual in a move. the boys 8-9 decided to tune up the saw and now I can't get it running...can you help me with the begining setings..Thanks John
Likely, they have adjusted the H and L jet needles and maybe the idle speed screw. Turn both jet screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting and should let the engine start and run. Start the engine and let warm up, then pull the throttle full on. Adjust H jet needle CW until the engine starts to speed up, but 4-stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW for better idle, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but allows the engine to continue to run. Hope this helps!
Sep 08, 2010 | Echo Garden
Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Jul 25, 2009 | Garden
I have a new EU2000i companion the idles goes up and down when the echo throttle is on runs fine when echo throttle is in the off position
YOUR IDLE SPEED SETTING IS OUT OF SPEC.IT SHOULD BE ABOUT 1750 RPM AND YOU ADJUST IT BY A PHILIPS SCREW ON TOP OF THE CARB
Jul 04, 2009 | Electrical Supplies
Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Apr 25, 2009 | Ryobi Cultivator
Open Questions:
Garden Logo
1,169 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
