Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Corrupted BIOS chip
How can i reprogram my bios chip please guide me;
  • cleanclover Feb 11, 2008
    My Bios hangs up while starting the pc. I have pentium 3 processor. What can be done? And where can i find any bios chip?
  • 40 Answers
Posted on Sep 28, 2007
  • 293 Answers
That depends on your motherboard Manual. It should correspond to your BIOS. Download the Motherboard's BIOS file usually in a Zip then the contents are .bin files. Then use the BIOS manufacturer's EPRON Programming tool. Which usually comes with a user manual. Just follow its examples. Good luck!
Posted on Sep 18, 2007
Can you sent me a picture of were to find the bios chip on the compaq presario f700 main board please. i can't change it if i don't know exactly, were to find it, in the main board thanks
The bios chip is not replaceable. If nothing is wrong with bios, live and let be. If bios is corrupt, a new motherboard is needed.
Mar 25, 2011 | Computers & Internet
My bios is corrupted how can i solve the problem
You can remove the battery to clear the BIOS - read the information from this link.
Although the link is about removing the password, the same things need to be done to reset BIOS to factory default.
Jan 05, 2011 | Foxconn (945G7MA-8KS2) Motherboard
Bios will not boot
I was going to advise "Try downloading and installing the Bios update from the manufacturer website. If the programming on the Bios EPROM was corrupted this should resolve the problem. " problem is even if you did this you wouldn't be able to install the update since there is nothing to tell the computer what devices it controls. Even a bad Bios battery will not cause this situation. You could try getting a replacement EPROM of the Bios from the manufacturer but I would either replace the motherboard or take it to a shop that might be able to reprogram the EPROM with the correct BIOS. I haven't priced an actual BIOS chip in a very long time but it should be relatively cheap.
Aug 08, 2010 | Computers & Internet
Emachines notebook m5310 corrupted bios recovery
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive. If you have a PCI video card you won't see anything on the screen because the boot-block BIOS only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufacturers send them for free.
Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or BiosWorld
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
Flash an appropriate BIOS to the corrupt BIOS and reboot.
Note: Use a flasher from MRBIOS. They are known to work best. You can find them at
Solution 4: (for Intel motherboards)
Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
Install the bootable upgrade diskette into drive A:
Reboot the system
Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
Turn the system off
Change the Flash Recovery jumper back to the default position
Leave the upgrade floppy in drive A: and turn the system on
Continue with the original upgrade
Oct 14, 2009 | Computers & Internet
First go into the BIOS setup screen and see iftyou can reset to the default values.
Upgrading a BIOS is risky for the very reason that happened to you. If anything goes wrong during the upgrade the it will have to be sent off and reprogramed.  If the BIOS setup screen did not work ,then your BIOS chip will now have to be reprogramed. That takes special equiptment. You wil either have to sent it off or I have seen places on the net to buy BIOS chips alread programmed. Do a serach for BIOS chips. They are removable from the holder.
Feb 07, 2009 | AOpen MX4SGVI-4DN2 (91.8B810.407)...
Apr 15, 2008 | Gateway M675 Laptop
1801 microcode patch erro
1801 microcode patch erro download free plz
Sep 17, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Toshiba Satillite A100 "TBX Error"
This needs BIOS Reprogramming. Go to the nearest service station for the Chip to be reprogrammed.
Sep 14, 2007 | Toshiba Satellite A100-S8111TD Notebook
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
195 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
