Question about HP PhotoSmart 7760 InkJet Printer
Too long to print
Like it typed the word "hi" and 20 minutes later cancelled the printing
Took out the color ink cartridge
Posted on Apr 19, 2009
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
My canon mx700 has stopped printing in color
Check the color cartridge to ensure there is is still color ink inside it, remove the color cartridge, shake it and fix it back, now try print, if did not still print color, i will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see problem.
Jul 01, 2011 | Canon PIXMA MX700 All-In-One InkJet...
How do you clear the print jobs so that you are not printing the same things over and over
How to Clear Out a Stalled Print Job In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Once you have restarted the Print Spooler, the jammed print job will be cleared from memory. Now you can go back and re-print all the jobs that were held up.
Feb 15, 2011 | HP Office Equipment & Supplies
My printer will not print. When you check the status of the document it says printing. When you cancel that it doesn't cancel. DAYS later the document prints all by itself. What's that about?
It's because the print queue is saved on the printer's flash memory. This happens when you don't cancel the queues properly or terminated improperly. To get rid of the issue, always try to give the command slowly and don't over load. If you are printing photos, try to make the file size small so that it'll not take long to spool and prepare for printing.
When the problem occurs, so as follows:
Cancel the queues from the print status box ("Cancel all documents"), if they are not cancelled, then turn off the printer (directly unplug the power cord from the printer), it you still see the printing status, keep on cancelling until everything's gone.
If the problem persists, restart your computer. Definitely the problem will be fixed.
It's also important to press the cancel button while the printer powers On.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | HP Officejet 5510 All-In-One Thermal...
Just installed new printer. cannonmp640
Hi there
Are you printing on photo paper? and they still wet after 20 minutes then this could be the photo paper itself not any good, or the only other thing is your inks, it should not take this long to dry.
I had this myself ones and it was the the photo paper.
All the best Pineworks
Mar 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Dell 5110cn will not print after sitting idle for approximately 15-20 minutes. Shutting the printer off and on will start it printing again. Power Save is set to 5 minutes of inactivity and it will print...
Follow the steps . To cancel a print right click taskbar and open the printer and cancel the print . Wait for a minute and check has it cancelled . If not then hold the Printer Power button for few seconds , this will clear any jobs which are saved in the memory of the printer.
Jan 16, 2010 | Office Equipment & Supplies
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
How do i cancel a print in queue? thanx
Depends on your operating system. Start > settings >printers. Or Start printers and faxes. Find your printer and double click to open. Select printer job and right click to get to delete/clear or go to the printer menu and cancel all print jobs. Another way is to turn printer off for about 20 minutes to clear its memory.
Mar 10, 2008 | Computers & Internet
HP PhotoSmart 7760 InkJet Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
