Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Briggs & Stratton Starter
My husband replaced the starter last week it has worked a few times just fine. This morning I went to start it and it won't start. It keeps doing the same thing that burnt up the starter last time. It won't turn over. When we replaced the starter we even bought a new battery for added assurance. What can be causing this problem?
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Gasket for briggs and stratton
I recommend  Jack's Small Engine Repair; they have always had the detail part I needed and their prices are among the lowest.
They will probably have an illustrated parts page for your model.
Jack's
Posted on Mar 22, 2009
  • 82 Answers
SOURCE: mower starter pinion gear won't stay on flywheel to start it
you can actually just replace the starter bendix
Posted on May 09, 2009
Knucklebstr
  • 222 Answers
SOURCE: I have a briggs and
The next thing you need to do is to check the coil. It may need a new one. Be sure to disconnect the ground wire from the coil to isolate it first. I'll link you to a video which shows you how this is done:
http://www.youtube.com/watch?v=AsRoSeyJ38o
I hope this helps. Best of luck to you.
James
Posted on Sep 17, 2011
  • 6468 Answers
SOURCE: my briggs and stratton 13.5 HP engine will not start
try and use jumper cables and jump the battery cables a bad one will draw to much amprage
Posted on Jun 04, 2012
**Help** I have a Sears Craftsman 18hp Briggs/Stratton riding tractor, about 10 years old. Just put a new battery in last week. Went to start this morning and battery was dead. The red cable that goes to...
Yes it very well could be the starter solenoid, with a digital volt/ ohm meter and the battery disconnected place the positive lead on the positive test lead . With the meter on ohms take the negative lead and touch the frame or engine . This will confirm weather or not you have a short to frame. If the meter reads 0.00 disconnect the starter from the system by removing the positive and ignition wires from th starter . Now individualy test each wire removed from the starter in the same process as above if ohm meter read ol ( over limit) the starter would be the best place to start. If the meter reads 0.00 would suggest there are other issues in the circuit and the starter may not be at fault.
Oct 14, 2013 | Craftsman 42" Briggs Stratton 20 hp Gas...
2006 Kia Rio will not turn over
the timing belt will not have anything to do with the motor turning over trying to start. First make sure u do have a very strong battery. Could be a bad connection or a broken wire to starter also.
Feb 07, 2013 | 2006 Kia Rio
The plastic starter gear keeps breaking on my 24 hp. I have inspected the flywheel gear and it is in good condition. I get one or two starts and then the gear breaks. This last time I thought it was going...
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
May 13, 2011 | Briggs & Stratton Starter Scott's Equip...
Starter turns engine too slowly
If the engine has not been taken apart, then the problem should be either too much oil or a weak battery, and lastly a weak starter. If the engine was "rebuilt" then the timing may be off.
Feb 10, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Nissan Altima 2000 Manual. Recently had remote starter installed and was working fine for a few days. This morning I remote started the vehicle and when I came out car was off. Try starting the car up...
the remote starter is not going to damage the starter, but if wired wrong it could damage the wiring or fuses, or run the battery down from a short.
Jun 11, 2017 | Nissan Altima Cars & Trucks
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 25 h.p. Briggs intek . The starter tries to engage but will click once and does not turn the motor. I have a new solenoid and a new battery. The starter and starter wire will get warm when tried...
sounds like starter is bound up,take it off engine and apply battery voltage to battery cable connection on starter and see if starter will turn over if not the starter is bad
May 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Starter spins but will not engage flywheel...
Check the flywheel for areas of damaged teeth also. Broken teeth on the starter drive gear may inticate damage to flywheel also.
May 20, 2010 | Briggs & Stratton Briggs Stratton Intek V...
PLEASE HELP! My husband is driving me crazy about Riding Mower
Sounds like the gear on top of the starter is stuck or broken. Inspect starter. If it's broken, the starter must be removed to replace the starter drive. You may need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
Jun 17, 2009 | Briggs & Stratton Garden
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
853 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
