Question about Kenmore 22422 Top Load Washer
I have a Kenmore 90 series top load washing machine, when it goes into the wash cycle, the aggitator functions , but jerks and makes a clicking sound. Also, causes the lights to blink in the house. I bought it new 10 years ago.
  • 2 more comments
  • wash board Apr 18, 2009
    I checked the speed controller and the aggitator jerks in ex-slow and slow speed... fast speed works OK...
  • wash board Apr 19, 2009
    The model number is 110.28912790. Thanks
  • wash board Apr 23, 2009
    We received th part today and installed it, but unfortunately the problem still exists. Any other ideas? Thanks
    our connection has 5 selections the replacement only had 4 .. ??
    President:
  • 331 Answers
Check your speed selector switch. If it's in between settings, it'll cause the symptoms you describe.
SG
Posted on Apr 18, 2009
  • 1 more comment
  • Tracy Farrell
    Tracy Farrell Apr 18, 2009
    There ya go! The diagnosis is a failed speed selector switch. If you could provide the model number, I'll look up the parts for you. (the model number is on the top panel underneath the lid in the back.)
    SG
  • Tracy Farrell
    Tracy Farrell Apr 19, 2009
    Wash,
    The part number you'll need is a 3406241.Here's a picture of it. If you don't have a local appliance parts retailer, you can order it from that link or you can get one from Sears. (Or you can just plug the part number into a search engine and price shop... I found one here for $37.25!)
    Watch this video to learn how to access the controls...
    That's all there is to it! (Please don't forget to "upgrade" the rating of this solution, Thanks!)
    SG
  • Tracy Farrell
    Tracy Farrell Apr 23, 2009
    Yes, following the instructions in the video (above), remove the cabinet. Down at the motor, you'll see a wire harness that connects to it. Make sure that all the wires are connected tightly.
    If that checks out OK, the next suspect is the timer. In order to definitively determine what the culprit is, I'm afraid some advanced diagnostic tools/skills will be required. In this case, I recommend calling a local appliance repair company. Find out what their service call/diagnostic charge is (ours is $65 for arrival, diagnosis and repair quote... if our customer chooses to have the repair done, we discount the diagnostic charge by 50%.) and hire a qualified tech to come diagnose it using his test equipment so you know EXACTLY what is going on here.
    I'm sorry that I directed you to the wrong conclusion to your washer problem. This is, after all, a free on line repair service. I do my best (based on my knowledge of all of the makes and models on the market) to conclude the appropriate repair. Your's, however is a bit of a conundrum.
    SG
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
I have a Kenmore 90 series top load washing machine, when it goes into the wash cycle, the aggitator functions , but jerks and makes a clicking sound. Also, causes the lights to blink in the house. I...
Get a repairman in to check for a damaged drive train on the washer and an electrician in to check the wiring in your house
Switching a high power electric shower on can cause some voltage drop which in turn causes the lights to dim for a short period.
But having a washer stalling on wash doing it sounds as if you have some major issues with the house wiring.
May 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Spin Cycle Works Some
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Jan 24, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore electronic 90 series washer
easy easy you need agitator dogs thats right the official name of the part is agitator dogs! 5 dollar part can chat you through the fix
Mar 25, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
287 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
