Question about Microsoft Xbox 360 Console
My controller wont connect to my xbox 360
I have tried every solution i have found and nothing works. I recently connected with an HDMI cable and thought that mite be the problem.
When i try to connect my controller just keeps blinking green but it is still able to turn the console on?
Please if you can help i would much appreciate.
I just bought this system and am very frustrated
cheers
casey
I believe you have to do a manual reconnection to the console from the controller.  You must press the button that is right next to the memory card slots untill the light ring spins.  Do the same with the controller ( button on top of the controller) It should also start spinning, then stop on one light comfirming that the controller and the console are synced.  This should solve your problem.
Posted on Apr 19, 2009
    Problem Solver:
  • 10 Answers
Well to troubleshoot it you could go out and buy the charge and play kit at game-stop best buy eb games
etc. there a hell of a lot cheaper than having to buy a new controller. or there's a button on top of your controller and a button on the front of your xbox 360 console press both of the buttons at the same time with your xbox turned on and it should connect.
Posted on Apr 18, 2009
I have no sound from Xbox HDMI connection.
you likely connected it with one or both units involved on and HDMI does not like that--prone to all sorts of audio issues.
If in doubt unplug the units and wait and plug back up making the connections first.
Jun 07, 2012 | Zenith " 50"" Class - Plasma - 720p -...
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
HDMI Problem
ok i think you need to reset the video settings here is a step by step procedure which you can follow
To reset the display settings of the Xbox 360 console to the default settings, follow these steps:
  1. Remove any discs from the disc tray.
  2. Turn off the console.
  3. Turn on the console.
    Note If you are using an Xbox 360 Wireless Controller, turn on the console by using the Xbox Guide button on the controller. Wait for the guide light to indicate that the controller has linked to the console.
    Note Make sure that you use the player 1 controller when you do this. The player 1 controller is indicated by the upper-left quadrant light on the console.
  4. As the console starts, press and hold the Y button as you pull the right trigger.
    Note This action causes the Xbox Dashboard to reset the display settings to the default settings. The console then automatically restarts.
Jul 10, 2009 | Microsoft Xbox 360 Console
TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Jun 18, 2009 | Televison & Video
Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
Jan 05, 2009 | Sony DAVHDX265 System
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
XBOX 360
How to Connect XBOX 360
This is the back of the Xbox 360. The ports for the power cable, A/V cable, and ethernet cable are pretty easy to find. When you set up your Xbox 360, make sure it is in a well ventilated area that is free of dust. Dust and overheating are the two main causes of problems in electronics so choosing the right placement for your Xbox 360 is important.
This is the standard Xbox 360 A/V cable that comes with the premium version of the Xbox 360. The wide silver end connects to your Xbox 360 while the other end connects to your TV. The Yellow (video) cable is for standard, non-HDTV sets. You will also use the Red+White audio cables for a standard set. If you have a newer TV or an HDTV set, you can use the Red+Green+Blue video connections along with the Red+White audio connections.
This shot shows what the back of most TVs look like. If you have a standard TV, you'll only have the Yellow+Red+White connections. If you have a newer TV or HDTV, you should have the same connections that are shown in the pic. This step isn't too hard since the cables from the Xbox 360 and ports on the back of your TV are all color-coded.
If, and only if, you have an HDTV and want to use your Xbox 360 in 480p, 720p, or 1080i resolutions you have to slide a little switch over on your A/V cable. On the end of the A/V cable that connects to the Xbox 360, there is a little switch that you'll need to click over. If you do not have an HDTV, you can skip this step.
Now that you have the audio/video cables connected, the next step is to hook up the power supply. Connect the two parts as shown in the picture and then connect the "power brick" end to your Xbox 360 and the other end to a wall outlet. The big power brick needs plenty of ventilation just like the main system so try to have an open space on a shelf for it. It is not recommended that you set it on the carpet.
Once you have everything hooked up, you are ready to go. Press the large circular power button to get things started. If you have a wired controller, plug it into a USB port behind the little USB door. If you have a wireless controller, hold the silver "X" button in the middle of the controller until the upper left quadrant of the system power button as well as the ring around the "X" button on the controller light up. If it doesn't light up, press the controller connect button on the Xbox 360 as well as the connect button on the top of the controller.
If this is the first time the system has been used, you'll have to go through an onscreen setup process. This is simply setting up your player profile, choosing HDTV settings if available, and/or signing up for Xbox Live service. The system walks you through everything.
Now you are ready to play.
Sep 06, 2008 | Microsoft Xbox 360 Console
XBOX 360 Elite HDMI problem
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
85 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
