Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony KF50WE610 720p scale is wrong
I have two problems with my set: 1 All 720p programs come out as 420p or 420i (I'm not sure which one but the set shows the picture as a shrunk size like 420p). Note that 1080i programs work fine. To debug I have tried to use both the HDMI and componet inputs and both show the same issue. 2 The TV has trouble starting: many times the light will blink and I hear a buzz upon power up. Sometimes the picture will come after a period of time.
  • Eric Rz Dec 10, 2007
    Thanks circuitcity for your response.
    I figured out the source of the first issue. It turned out that the cablebox was somehow put into an incorrect mode of operation. The other box that was incorrect is my netgrear EVA8000, video streamer. They must be setting up the incorrect signal for my TV because I have to use 1080i and not 720p. All other 720p sources are working, including my DVD player.
    The 2nd issue doesn't appear to the the lamp because it has been a few months and the lamp is now working without any problem - it starts without any buzz. In other words, the problem is very sporadic. Typically when lamps fail, they no longer work. In this case, the lamp will not work on some occasions and it has been doing this now for over 1 1/2 years. How can a lamp continue to work for this long without completely failing?
  • 137 Answers
(1) what is your source? cable box? satellite? Your source could be your problem. Your TV just pick up what is sent to it.
(2) Light blinks and buzzing is a symptom of a lamp going bad. Just change your lamp. lamp part number XL-2100
Posted on Dec 09, 2007
I created a barcode & used PLU programs 100/200/300 to register it with my ER-380M. The barcode works ok with Price Enquiry but if scanned for a sale brings up a "Scale Error". Where did I go wrong ?
It sounds like you set it as a scale PLU so now it is trying to check the weight of the product on your scale. Set it as a non scale PLU
Apr 19, 2017 | Retail Supplies
Technic SL5200 turntable speed is to fast on 33/45
1. Some of these turntables were designed to work on multiple voltages. If yours has a voltage adjustment make sure it's set for 110 or 120 V (North American) or whatever your power line voltage is. 2. Does it have a variable speed control with markings around the platter that tell you when it's on speed? if so, make sure you're reading the right scale when you adjust speed. Some Technics turntables have scales for both 50 Hz and 60 Hz (North American) line frequency, with two rows of dots for each, and if you're looking at the wrong scale when you adjust the knobs you'll get the wrong speed. 3. If neither of these solves the problem, you'll have to take it in for service.
Sep 30, 2014 | Technics Audio Players & Recorders
Ps3 picture pixalated
Make sure the video cables are securely attached to console and TV. Check the game for smudges, scratches, or dirt. Make sure the video resolution settings are compatible with your television like 1080p 720p instead of 420i. Just some ideas
Sep 15, 2012 | Sony Playstation 3 (PS3) Console
I keep getting e on scale dont know what i did wrong setting it up Model bfm884dqn-60 it is for 4 users height of 5 3 1/2 is displayed pls HELP Thanks
I think that those numbers are for the spacing of the feet? I'm not sure what that number is, but anyway you have to push select 3 times and it will save and then the scale will zero out. After that you can push one of the four buttons and program you height/age/gender. I think they really made this scale kind of user difficult.
Sep 03, 2010 | Sunbeam Healthometer Body Fat and Weight...
TV set always starts up indicating 420p. How do I get it to 1080?I have Bell expressvu HD
is your cable or sat in HD(720p, 1080i, 1080p) over the air broadcast in the usa is in digital so it should start at the highest res available in your area
next are you using HDMI or composite for your cable or sat going into your tv if not your not going to get higher than 420p because A/V and S-video do NOT support HD
check your cable/sat box is it HD(high def) or SD(standard def) if SD going through cattv/attn in your only going to get 420p
now for changing the resolution its automatic it goes to the highest setting on its own
you can control the resolution through your cable/sat box, blue ray/hddvd player and other HD devices connected to the tv through the options menus of those devices BUT only when connected through
HDMI(supports 720p, 1080i, 1080p)
composite(supports 420p, 420i, 720p)
A/v and S-video(supports 420p)
cat tv/attn in(supports 420p, 720p, 1080i, 1080p) only supports what the tuner will do
Feb 11, 2010 | Hisense LHD3204US 32 in. LCD HDTV
How do i program the taylor body fat scale
From the Taylor web site
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Jan 15, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
My proscan tv is on 420p setting. how do i set it to 1080p?
You do not set the resolution at the TV, the TV will display what video resolution you feed it, I also doubt that the your 19" can do 1080P.
Dec 06, 2009 | Proscan 19LA25Q 19 in. LCD Television
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Programming CONAIR WW 35 CHA Weight Watcher Scales
Press Set and choose the P-##(used to help you recognise which user, so skip your P-## and go to another number by using the Up/Down keys, once you have selected a P-## press Set to begin inputting details, you can input details with Up/Down keys with Set to confirm an input.
Jan 19, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
Conair weight watchers ww37gd scale
To set
1. Push the set button, you will get ------
2. Push the user
3. Push set again the user number will blink 3 times and show 0.0
4. Get on the scale- when it shows your weight push the set button. This is your start weight
5. Then it will automatically take 10% and show your goal.
6. Push the set button again this will set the goal
To Weigh
1. Push the user number that you set up the P-? number will blink 3 times and show 0.0
2. Get on the scale it will show in this order
a. your weight now
b. your weight since the last time you weighed
c. The total loss toward this goal
d. Total needed to reach your goal
Mar 18, 2008 | Computers & Internet
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
