Question about Whirlpool DU840CWD Dishwasher
Water drainage problems
I have a whirlpool DU840SWKQ0 and the drain is clogged with food pieces. Is there a way to remove the drain to clean it? If not how do I go about cleaning it so that the water will drain properly. Thank you for your help.
5 Suggested Answers
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
  • 188 Answers
SOURCE: Dishwaher does not clean, upper rack
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Posted on Mar 13, 2009
SOURCE: specks of "sand-like" food on my dishes; water not draining
I bought a replacement filter and that dramatically cut down on the amount of "specs." Now there are only a few in some of the glasses. I also cleaned out the drain underneath the screen, there were peas and corn in there, I just used a shop vac to **** them out. Seems to be much better now, I think a good inside cleaning of the washer will help out too. Hope this helps...
Posted on Mar 21, 2009
SOURCE: Maytag dishwasher filter (?)always clogging
How do I take apart and clean the filter, I've gotten the screws out but to do now?
Posted on Sep 18, 2009
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
My whirlpool quiet wash plus diswasher is not draining water. How do I fix it?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 14, 2011 | Dishwashers
Water left in the bottom of the dishwasher, after a full cycle.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
Water left in dishwasher after cycle is finished
Hi
Daniel
Aug 03, 2011 | Whirlpool Dishwashers
Water left in bottom after running dishwasher
Hi
Daniel
Aug 01, 2011 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is not draining what could be the problem
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 19, 2011 | Whirlpool Dishwashers
Water will not drain
Hi
Feb 20, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher will not pump the water out.
Hi
Feb 09, 2011 | Whirlpool Dishwashers
Washer does not drain water
The major reason for this to happen is the clogging of the drain pipe of the washing machine. If, even after you clean the drainage hose, the problem persists, there may be other problems.
Next possibility could be that the drainage pump which drives the water out of the drainage hose may be clogged! So, remove the drainage pump and clean it. That should solve the problem. it might also be that the belt of the drainage pump motor may have loosened. If this is the case, you have to simply tighten it.
Take care.
May 30, 2010 | Whirlpool LSR5132PQ Top Load Washer
Dishwashers Logo
127 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
