Question about Homelite 'Yard Broom' Leaf Blower
Can not attach the debris removale pieces
Can not get the cover off in order to attach the debris removal tube and I can not get the bag on.
  • 398 Answers
Sometimes there is a clip you have to pry at with a screw driver, the bag shoul djust twist on. let me know if this isnt enough help
Posted on May 17, 2009
How do you attach the bag to the barracuda 2595 blower
The motor housing has a spring loaded, hinged cover over the fan blades (so you don't chop your fingers off when using it as a blower). Open the cover using a screwdriver or narrow tool. Holding the cover open, attach the vacuum tube. Attach the collection bag to the discharge port (same place you attach the blower tubes) and secure in place using the velcro strip sewn onto the bag. Adjust the ******** the bag to fit your shoulder, turn power on and go. To empty the bag, just unzip the bag completely. Make sure you tighten the velcro strip so the bag doesn't come off while you are sucking up leaves.
Oct 11, 2011 | RTO Weed Eater Electric Barracuda 2595...
My Riccar Upright leave lines of debris when I use it. Can you help?
Inspect the filter.Open the secondary filter on the base of the vacuum to ensure that dirt and debris have not collected on the filter, as this will limit motor performance. Remove the filter from the dust compartment and rinse with water to clean. Allow it to dry completely and return to the dust compartment.--------
Also check if dust bag is got over full and that is causing the problem.Open the dust compartment, take the old dust bag out of the bag holder and discard. Open the end of a new dust bag and attach to the dust bag holder. Close the dust compartment and tighten the dust cover.Also check properly that dust compartment is not got loose. Open cleaning attachment and check the hoses and nozzles on the frequently to ensure that they are free of dirt, obstruction or hair.Also inspect the brushes, if there is already dirt got stuck in the brushes and that is causing the problem.Clean the brushed.---------- This will help, to confirm where the problem is and to resolve the dirt /debris issue.----- Thanks.Helpmech.
Sep 06, 2011 | Vacuums
Hi My bissell proheat 2x 9500 is making a loud noise when the brushes are moving. I replace both belts and cleaned the brushes. Can you think of anything else it could be.
Hello there,
Try using other brush attachments, as broken bearings in a brush attachment will cause noise. If these troubleshooting techniques do not work, you may need to service the engine.
Remove the filter and bag of the machine and make sure that they are not clogged or full of debris. Clean any filters according to the instructions for your model or replace the bag. Excessive debris will make the engine run noisily.
Inspect the hose of the vacuum and remove any large debris that may be clogging the inside of the tube. Large amounts of dust, as well as stones or other hard materials that bounce, may cause a loud noise in the engine.
Remove the housing that conceals the engine of your machine and inspect the fan for damage or clogging. Remove any dirt or debris that may hinder the movement of the fan. Inspect the fan for any damage such as bent or excessively sharp blades. Replace the fan blades as needed; contact your vacuum manufacturer if the fan is damaged. The replacement part will include instructions.
Tighten the fan with a ratchet if it is loose on the assembly. A loose fan will make a rattling sound as the motor revs.
Wipe dirt and dust from the frame of the engine. Large quantities of dirt or dust around the motor can cause it to overheat, which can cause vibration and loud noise.
Look for corrosion around the engine. If the engine is corroded, it must be replaced.
Grease the bearings of the engine if you hear a grinding noise from the vacuum. Greasing is often performed through ports in the engine, or by removing the bearings. However, the actual greasing method is model-specific. Consult your owner's manual or send the vacuum to a service professional for this service.
Inspect the inside of the vacuum cleaner for other worn parts or broken pieces. Worn or broken pieces can cause loud noises to occur. Remove the broken part and order new materials from the vacuum manufacturer or take the machine in for service.
Hope this information was helpful to you. All the best. Elect_Comp
Sep 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a clog in the vacuum line that comes out of the face that runs to the vacuum tube to the bag
To check for blockage in the fan housing, remove the bag assembly. Grip the lower bag housing and turn it counterclockwise for removal. If it has not been removed regularly to clean out debris, it may be hard to remove. Insert a screwdriver between the housing and the motor for leverage. For easier installation, wet the seal on the motor outlet before re-installing the bag assembly. Remember that the motor will not run unless the bag housing is fully attached.
Feb 13, 2011 | Kirby G6 Bagged Upright Vacuum
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 | Garden
Clogged drain tube on Bosch Axxis condensing dryer
just after having the same problem on my Bosch condenser dryer, remove the top cover by removing the two screws on the rear panel, slide the top cover aft to remove it. when the cover is lifted clear you will see where the drain hose to the collection container is installed, look at the aft l/h corner, you will see a black hose comming up through the corner which attaches to a white plastic end piece which is clipped to the frame of the dryer. Release the clip which hold the white end piece, pull the end piece from the hose, there's a good chance that the end piece is block with fluff etc, blow through from the opposite to clear any blockage, blow through the hose to make sure that its not blocked also. Hopefully this will cure your problem , rebuild in reverse order ----- Hope this helps
Jul 25, 2010 | Bosch Axxis WTL 6106 Electric Dryer
I need to remove the outer bag from my Kirby upright. The inner bag was not attached and there is mung everywhere.
In order to remove the outer jacket from your Kirby do the following.
Detach the top bag clip from the handle support. There is a plastic piece, just below the outer jacket, called the mini emptor. Turn it to the right to remove the entire bag assembly. Removing the outer jacket is dificult and even harder to put back on so this is what I would do.
Unzip the outer jacket as you were going to change the bag. Remove the paper bag. You will then see a long black tube, that has a 90 degree elbow at the top. That elbow is attached to the inside of the bag with a snap type strap. Remove the strap, then you will be able to move the tube, while you clean out the inside of the bag. When finished put everything back where it was.
Apr 28, 2010 | Kirby G4 Bagged Upright Vacuum
No suction of the water from carpet after soap is applied
Hello :
1: A vacuum pulls air through the bag, then through the tube attachment and then through the base (with the spinning agitator brush).
2:Check for signs of suction. Remove the tube attachment from its cradle and, after turning on the vacuum, put your hand to the end of the tube. Is there any suction at all? If there is a little bit of suction then you may have a clogged air tube.
3:Check the vacuum bag. It may be very full. If it is then remove the bag and replace it with a new bag. Check the suction power again. Has the suction improved?
4:Check the tube attachment. Completely remove it from the vacuum. You usually have to twist and pull the tube attachment out of place at the point where it connects to the back of the vacuum. Check the suction power again. This time you place your hand on the vacuum right where the tube used to come out of the back of the vacuum. Has the suction improved?
5:If the suction power has improved then you probably have a clogged tube. Dog hair, people hair, leaves and more can get lodged in the tube slowly over time and then suddenly block the tube completely.
6:Clean the tube by first trying to shake the debris out of the tube. If this does not work then go outside and run a hose through the tube. Use a pressure nozzle if you have one. Run the hose through one end of the tube. Then run it through the other end. Repeat until the debris is disloged. Dry the tube and then reattach to the vacuum.
7:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
8:Check the air hose in the base of the vacuum. This hose is usually pretty short and you can see if there is any blockage. If you see blockage then try to remove it. You may need to reach into the hose with a tool (like a screw driver or something long).
9:Has suction power improved or returned to normal power? If yes then you can stop reading now. If not then read on.
10:If you made it to this step then you may have a problem with the motor on your vacuum. If this is the case then you will need to take the vacuum in to a repair shop.
Things you will need :
1 Philips screw driver
1 flat head screw driver
Warning :
# Always unplug electrical devices before you work on them.
# Never work on electrical devices around water or when you are wet.
I hope this will help .
please rate !
Apr 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Kirby sentria
remove the cloth bag from the bottom it twists counter clockwise, un clip the bag from the top remove the head piece, turn the belt lifter clockwise and release the lever to remove the head, take off the head, in your attachments there should be a screen that covers the impeller that the belt rides on it goes on like the brush head, put your hose onto the bag port by turning clockwise. there it is it will not work without the screen cover. thanks Rene
Aug 29, 2009 | Kirby G6 Bagged Upright Vacuum
Bottom cover removal
Can you attach a picture of the bolt you speak of  Or the bottom of the machine?
Oct 17, 2007 | Jura Capresso EspressoPRO 112 Espresso...
Homelite 'Yard Broom' Leaf Blower Logo
57 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
