Question about Husqvarna Garden
What oil to petrol ratio does this engine run on?
What oil to petrol ratio does the Briggs and Stratton XC375 engine run on, as used in the Husqvarna/Sovereign lawn mower?
  • Anonymous Mar 19, 2014
    Petrol ratio
  • 62 Answers
Http://www.briggsandstratton.com/maint_repair/manual_and_more/
Go here and enter the proper information, and see if they have the manual available.
Posted on Apr 18, 2009
Surely the XC375 is a four-stroke engine and does not require a petrol/oil two-stroke mixture to run correctly!
Posted on Jun 30, 2010
Engine seems to run fine as long as the plug is not fouled however it smokes and leaks oil from the fuel pump. It seems as though there is too much crank case pressure
oil from the fuel pump may indicate a failure of the diaphragm of the fuel pump and petrol is getting into the sump
that will raise the oil level to a point where the oil ring can longer control the oil getting to the top of the piston
it is possible that the sump breather hose is blocked or if it has a small pvc valve that that is blocked
May 06, 2016 | Briggs AND Stratton Intek Briggs &...
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
V16 briggs.petrol in oil
your float isnt shutting off gas at the carb its running threw the carb into the engine need new needle and seat for carb
Mar 17, 2013 | Briggs & Stratton Garden
98902-2065-B1 briggs & stratton oil:petrol ratio pls
This is a 4 stroke engine which requires an sae 30 weight oil in the crankcase and straight gasoline (petrol) in the fuel tank
Jan 19, 2013 | Briggs & Stratton Garden
What 2-stroke mix for a Snapper mower (Briggs & Stratton 6.5 HP)?
USE A 32:1 MIX. THE MORE THE RATIO OIL TO GAS MIX RATIO THE MORE COOLER AND LONGER LASTING THE ENGINE WILL BE. 40:1 IS FOR FULL OUT TROTTLE CHAIN SAWS ECT.
Mar 13, 2012 | Snapper Garden
2 or 4 cycle oil for a Ranch King 6.0 lawn mower? What kind or type of oil should use?
If you mean oil for the crankcase use need 4 cycle oil Ususally 30 weight and don't over fill Most small engine do not even take a quart only about 20 oz.
If you mean to mix with gas ( I doubt this) but then you need 2 cycle oil depending on the mixture usually about 3 oz to a gallon of gas (3.2 oz / gal = 40:1 ratio, 2.5 oz/ =50:1)
May 24, 2011 | Briggs & Stratton Garden
Do you have to make a petrol/oil mixture for briggs ans stratton lawn mower engines?
Typically no, it uses gas only in the fuel tank and oil in a separate tank. To make sure do you have a separate cap for oil? If yes then you only use gas not a mixture of gas and oil.
Aug 18, 2010 | Briggs & Stratton Garden
My Briggs & Stratton Diamond I/C 13.5 HP has
it could be worn out piston rings letting unburnt fule past into the sump oil
Jun 20, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Briggs & Stratton 3.5hp running problems. I am unable to get my B&S to run smoothly It starts and runs but continuously but hunts all the time and does not get up to full power. any sugestions of...
people often leave petrol in these types of engine when not in use for long periods and susequently the petrol then turns bad, the only way to resolve this is to take off the carburettor and clean out espesially the main jet
Mar 21, 2010 | Briggs & Stratton 30-Amp Extenda Panel -...
Garden Logo
438 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
