Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
There is a cut at the end of the hose. Is there a way to cut the hose at the split and reattach it to the connection? Thanks.
I have a split in the hose on our Dyson DC-7 at the end of the attachment. Is there a way to cut the hose at the split and reattach it. Thanks.
  • 61 Answers
Unfortunatly the amswer is no you will have to replace the whole part.
Posted on Apr 18, 2009
My kirby heritage II vacuum hose has a cut near the end of the metal nozzle. Is there a way to replace just the hose or even just cut off the damaged section and reattach to the metal nozzle?
We do carry a brand new Heritage II hose here. I do not know how you would cut and reattach the hose without losing hose integrity. You can try submerging the end in warm almost hot water and pulling off the end, cut the hose, and squeeze the end back in. But your hose will be shorter and I am not sure if it will work depending on how it is torn.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Sep 13, 2014 | Kirby Heritage II Vacuum
BAD SUCTION WHEN USING ATTACHMENTS
Bad suction often means a blockage somewhere, so check all the possible areas for blockage that relate to the hose. Also, check the hose for splits, as they often split at either of the ends - this would greatly affect the suction when using the hose and tools (and can sometimes only be spotted when the hose is stretched at the end points).
Jul 21, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Split suction hose
try e spares on the internet they have most parts
and to replace is very easy
Mar 20, 2014 | Miele S7260 Bagged Upright Vacuum
Vacuum not picking up much but the hose attachment has no problem
I assume you've checked for blockages and that there's a useful length of bristles on the brush roll. Turn the machine over, and just behind the brush you will see a short length of clear plastic tubing with spiral reinforcing. That tube often splits, so there's an air leak and consequent loss of suction at the brush. A split may not be immediately obvious - to get the tube off, pull it off from the motor end and then unscrew it at the brush end. As a temporary measure you can cover a split with tape, but the tube undergoes so much flexing that tape is rarely effective for very long. A new hose (it's called the internal hose) is not expensive and is the only permanent solution.
If the internal hose is not split, post a reply here and we'll see what else we can think of. Good luck!
Jun 05, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction perfect when in upright position, but when tilted to actually clean there is total loss of suction - cannot see blockage anywhere. Thanks for your help.
If you are confident there are no blockages, look underneath, where the brush is, and you will see a short length of reinforced clear plastic hose. This often develops a split which results in loss of suction. You can pull the hose off at the motor end and then unscrew it from the brush end to examine it thoroughly. If you find a split, it's best not to try and tape it up (except as a very temporary measure) - a new one is not expensive.
Feb 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Losing sucksion
If you look underneath your DC07 you will see a short length of clear plastic hose with spiral wire reinforcement. Quite often this hose splits (which lets in air and reduces suction at the brush head). Check this hose carefully, as a split is not always immediately obvious. If necessary, remove it by just pulling it away from the end nearest the motor and then unscrewing it from the brush end. A new hose costs very little so it's hardly worth trying to seal a split with tape.
If this is not the problem, post a reply and I'll try again. Good luck!
Jan 15, 2010 | Dyson DC07 All Floors Bagless Upright...
My vacuum hose has split very close to the handle- how do I remove the handle, cut the hose at the split & reattach it to the handle unit - Centralux central vacuum system. Where can I find a diagram...
Do Not Cut the hose!
It has wiring inside to control the vac and power head. This is a swivel handled hose with both low and high voltage contacts in it. The same wiring which gives the hose its ribbing, is conducting current for two applications,
If your hose has a switched handle, a very experienced, trained AERUS Electrolux tech will a have a tough time doing this job and will likely refuse as it is not recommended per company policy.
You can purchase a shrink wrap tube which will prolong the life of the hose if it has not collapsed, however this is a short term fix.
I could walk you through this as I have done it before ...Unfortunately, even if you were able to dismantle the hose successfully you would not be able to purchase the wire terminals which you would cut off the end when shortening . Sorry its a proprietary part.
Sep 20, 2009 | Electrolux Centralux Vacuum
McCulloch MC1275
I had the same problem today. It turns out part of the steam hose was kinked. If you feel along the black tubing - this covers the actual steam hose, you may feel a hard spot where the inner hose may have kinked. Mine was near the end so I cut into it, cut out the kinked part, and reattached the hose to the endpiece - where it screws onto the body. If you do have a kink you will at least have to cut through the black tubing - careful not to cut the inner hose; you will see the nylon wrapped hose inside and can try to fix it. I was unable to unkink it without cutting it, you may have better luck, or you can do what I did. If you decide to, once you take apart the endpiece you'll see how it all goes together, pretty easy to figure out. Alternatively you might be able to buy a new hose through http://www.topinnovations.com
Hope this solves your problem, if you haven't already. Good luck.
Jul 22, 2008 | McCulloch MC1275 Steam Vacuum
How do you remove the plastic end fitted to the flexible hose
Not necessarily. Some Dyson models have an all inclusive flexi hose which attaches to the handle spine. Check EBay for replacement flexi hoses - UK has many sellers - or handles which have the metal pole and the flexi tube attached.
Alternatively take off the flexi hose from the bottom rear of the Dyson - it can come out via a press in lock release but it may take some time to do this. Once that is done the flexi hose should come down freely from the metal tube. If it doesnt then you may need to consider both replacements.
Dont forget to rate, thanks.
May 25, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
293 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
