RCA RTD258rv in my motor home is not working
I had some kind of voltage surge & my dvd home theter went out, along with the outlet it was plugged into. On its own, outlet returned to life, but rca unit is not working. Does it have any kind of a reset? If I have to replace it, need a source to obtain onr. HELP!!!!
  • Thnder10 May 18, 2009
    Peter we had the samething happen to us but now what we get is bad disc. Was your in a Monaco Coach? We have been batleing with Camping World since Monoaco has filed Chapter 11. Camping World is who we bought the RV from and of course it is past the warrenty but we have only used it three times since Jan 08. Among other things
atlasuk2007
  • 85 Answers
SOURCE: RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Posted on Aug 22, 2007
shanth
  • 108 Answers
SOURCE: RCA RT2760 Home Theatre
1. Problem with Power supply unit
2. Problem with power amplifier unit.
Contact service centre
Posted on Dec 22, 2007
SOURCE: will not turn on
I have an RCA projection widescreen TV model # D52W19B and was watching when it made a pop noise and turned itself off. Now when you try and turn on you get a high pitch beep but TV keeps shutting itself off with no picture or anything. Could this be the bulb went bad?
Posted on Jan 14, 2008
MrLard
  • 94 Answers
SOURCE: RCA Inputs for Pioneer AVM P100
An I-Pod connection box connects to the RCA inputs and the IP-BUS connection.
Here is a picture from the AVM P7000R manual showing the connections the IP-BUS lead is marked by the red square.
The cable looks like this -->
and you can buy it here ->LINK<-
Posted on Jun 26, 2008
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Posted on Jul 02, 2008
First the screen picture started to flash between the picture and a blacked out screen, then it just completely turned black along with thin lines across the screen horizonally. I checked all the...
I'd Guess it'd be something with the lightning or you have to wait for a while for the entire screen to pop up while its turned on thats what happens to my grandma.
Oct 29, 2013 | Sceptre 32" 1080p LCD HDTV X328BV-FHD
What type of AC adapter does the T790 ellictical machine needs also the voltage and polarity
Dear Sir:
Please read carefully:
Your treadmill, like any other type of sophisticated
electronic equipment, can be seriously damaged by
sudden voltage changes in your homeõs power.
Voltage surges, spikes, and noise interference can
result from weather conditions or from other appliances
being turned on or off. To decrease the possibility of
your treadmill being damaged, always use a surge
suppressor with your treadmill (see drawing 1 at
the right).
To purchase a surge suppressor, see your local
PROFORM dealer or call toll-free 1-800-366-7278
and order part number 14657. Use only a single-outlet
surge suppressor that is UL 1449 listed as a transient
voltage surge suppressor (TVSS). The surge
suppressor must have a UL suppressed voltage rating
of 400 volts or less and a minimum surge dissipation of
450 joules. The surge suppressor must be electrically
rated for 120 volts AC and 15 amps.
This product must be grounded. If it should malfunction
or break down, grounding provides a path of least
resistance for electric current to reduce the risk of electric
shock. This product is equipped with a cord having
an equipment-grounding conductor and a grounding
plug. Plug the power cord into a surge suppressor,
and plug the surge suppressor into an appropriate
outlet that is properly installed and grounded in
accordance with all local codes and ordinances.
If you need Extra help please reach me inmediately.
sincerely. blessing.
E.CUADRA
MANAGUA, NICARAGUA .C.A
Sep 13, 2011 | Reebok Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
Unit won't power on
Go ahead and turn off the computer and disconect all the peripheral devices along with the disk in the cd dvd drive. Do a power drain and then restart the computer after 1 to 2 minutes. Hope it will work.
May 12, 2010 | Sony DVP-NC85H Multi-disc DVD Player
Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Aug 31, 2008 | Nintendo Wii Console
RCA HOME THEATER SYSTEM REAR SPEAKERS NOT WORKING
cheak the mode u are in theter mode reg sterio mode wont do the back ok cheak settings dsp modes
Jan 20, 2008 | Audio Players & Recorders
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
445 people viewed this question
 Grubhead
Grubhead
