Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
The problem is that when turn on the television
The problem is that when turn on the television everything turns on but the screen does not. It just stays off
  • Marco M May 11, 2010
    do you noticed if panel turns on? or just picture does not appear?
The red led lightsbut doesn’t turn to yellow after power on and black display
power on,checkXP801 4 pin standbyis low≦0.5Vvoltage
IF YES...(if no goto *)
checkXP801 pin 11,D6V
XP801 pin 9,VDD
IF yes
check I2Cbus
IF normal
1、check VPC3230、PW1235power circuit
2、check VPC3230、PW1235reset voltage
3、check VPC3230、PW1235peripherally circuit
IF abnormality
check buscircuit and PCBwire
*if no
check N803、N804output voltage
no
1、check PW113power impedance
2、checkN803、N804
yes
check X3 14.318Mcrystal
no
change Y2crystal
yes
check PW113RESET pin voltage
no
checkresetcircuit
yes
check AM29LV800BT toPW113 address、data、control
changeAM29LV800BT orPW113 and wirebetween them
D6V:steady voltage to 5V supply for VPV3230、AD9883 analog power;5V-ST:standby power,to PW113、AM29LV800BT(ROM)、24LC32、MAX202E;VDD(3.3V):VPC3230、MST9885、DS90CF383 power;+32V:RF tuner tuning power;A6V:steady voltage to Av board 5V etc. ;A12V:steady voltage to AV board 8V etc.;12VAMP:sound amplifier TA2024 power
Posted on Apr 23, 2009
  • icysteve38 Apr 23, 2009
    Hmmm... lets try to clarify this a tad,
    if no
    -if above does not checkout then-
    2、checkN803、N804
    -if it checked out OK then-
    change Y2crystal
    checkresetcircuit
Hooking up antena & converter box
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
Dec 02, 2012 | GE 27GT271 TV
SyncMaster SA10, my screen turned green, i've tried everything but it's still the same. Help ?
The Blue and Red drives are missing and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Samsung SyncMaster 940MW 19 in. LCD...
Why would our proscan big screen just turn off and then not turn back on. Everything else has power. And also when we tried to unpluge the power cord on the back it sparked. Please help. --- model number...
I JUST GOT HOME AN TRIED TO TURN MY JVC PLASMA TV ON. THE TV WILL NOT TURN ON. EVERYTHING ELSE HAS POWER TO INCLUDE THE TV BUT THERE IS NO PICTURE OR SOUND. BLANK SCREEN. THE BLUE POWER LIGHT IS FLASHING ON AND OFF. THE MODEL NUMBER LT-42P789
Jul 16, 2009 | Proscan 19LA25Q 19 in. LCD Television
Hitachi big screen tv
if ths image is stuck on screen the solution should be white wash
Mar 01, 2009 | Hitachi 55HDS69 55 in. Plasma Television
A solid black block covers majority of screen - all else works
Try turning off the text box function of the closed caption decoder.
Sep 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Screen turns black after a few seconds
Check the software and if is is not BX23U-1.5.0.0_03531 upgrade it by downloading the software from www.p4c.philips.com onto a USB stick. If that don't fix the issue change the small signalbaord.
Aug 19, 2008 | Samsung Televison & Video
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
199 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
