Question about RCA RT2500 System
Can't figure out how to connect a subwoofer to my RCA RTD315W
I have a separate set of surround sound speakers and bought an RCA RTD315W Home Theater System. I connected my speakers to the RCA Home Theater Systems (receiver/dvd player/tuner), but can't seem to figure out how to connect the subwoofer, since it has a jack instead of the wires.....how can i solve this problem? HELP!!!!
  • 151 Answers
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
Posted on Apr 19, 2009
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
How do i program rca home theater
How to Setup a RCA DVD Home Theatre System RTD325W ...
? 10:31
https://www.youtube.com/watch?v=20dRIj8KWPU
Jan 28, 2012 - Uploaded by TheHandofOdd
Just how to setup and get the optical cable working for those who need help.
RCA Home Theater System Set Up - YouTube
? 5:37
https://www.youtube.com/watch?v=j0UhnbrjJto
Sep 14, 2012 - Uploaded by gangstafly5000
The RCA hooked up to 43' plasma Samsung. ... RCA Home Theater System Set Up. gangstafly5000 ...
RCA 5.1 Surround Sound 1000 Watt HOME THEATER ...
? 13:06
https://www.youtube.com/watch?v=1xfEmkwCwyA
Oct 18, 2014 - Uploaded by bigtruckseriesreview .
I bought recently rca system home theater and makes strong fan.... +Aiden woodruff Change he settings to surround, and make sure all of the ...
How to Set Up an RCA Home
Jan 13, 2016 | RCA Televison & Video
I have an RCA rtd315w home theater system and I am trying to connect my xbox to it so it will play the sound. I have my xbox connected to my tv through a component HD cable. How can I get the xbox sounds...
run yellow cable from xbox to TV vide input for picture!, now run the red/white cables to AUX ibput on the RCA and push function till you see aux and poof, you got Video on the tV and audio from the surround sound.
Sep 05, 2013 | RCA Rtd315w Dvd Home Theater System...
I have an rt2870 and am just wondering where i connect the yellow subwoofer cord to the TV at, and i set my tv setting for the surround sound
You shouldn't connect the subwoofer to the TV. Just connect the Right and Left audio cables (red and white RCA plugs) to the TV audio out and then the other side goes receiver's audio in. If you are using the subwoofer that came with the unit, connect it to the sub port (purple and grey or black striped). The red and black striped cable goes to the subwoofer control.
If you are using another active subwoofer, connect it to the RCA jack labeled Subwoofer Audio OUT.
If you have a 3-plug RCA cable that is a composite video cable. The yellow plug carries the video, the red and white carry the audio signal. This cable is most often used for connecting older VCRs and game systems to a TV (or newer devices to an older TV). Thus leave the yellow jack dangling if using it for an audio cable.
Set your TV to use the external audio speakers and the receiver will take care of the signal to the subwoofer. (You only would connect the speakers individually for a computer sound system.)
I hope this helps.
Sep 19, 2010 | RCA RT2870 Theater System
I just bought an rca surround sound rtd315w - mp3 won't work
You must select that input with the RCA surround sound
Apr 20, 2010 | Televison & Video
I just bought a Yamaha 5.1 system with rcvr RX-V365 i have HDMI to tv then HDMI to RCVR then another HDMI to DTV. Problem cant seem to get picture AND sound together through RCVR. depending on what setting...
RX-V365 doesn't support sound over HDMI. It can switch the video+audio from HDMI in to HDMI out, but can't play the sound through the speakers. You need to connect the audio separately via optical or coax digital cable.
Mar 19, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
RCA Home Theater model RTD315W
  • You need to change your audio settings in your TVs audio menu. Sounds like it is set to play only external source when connected, There will be a setting for all speakers to play, including TV's. Have your TV's volume up just a hair when changing your settings and you will be able to hear when it changes to what you want.
Jan 27, 2010 | RCA Audio Players & Recorders
I have a RCA RTD315W home theater system. Are the speakers suppose to work with regular TV? Or does it just work in DVD mode? If it is suppose to work with the TV do i need a HDMI cord to make it work?
I have a RCA DVD Home Theater System, RTD315W. The "On/Standby" light is on (displaying a blue light), no other features are working. When I press a feature buttom, the blue light goes out. System just isn't working. System haven't been exposed to water/moisture. What the problem?
Dec 30, 2009 | RCA RTD315 Theater System
COBY cs-p63 ,how to connect to a computer
with this system it comes with connector cables, on one end is 3.5mm to go into your computer and the other end is rca jacks that go into the subwoofer, all the speakers go to the subwoofer. your computer must have all 5 ports to get true surround sound, if not, just hookup the ones for the FL FR and run RCA split from that to the speaker output on your computer.
Feb 09, 2008 | Coby 5.1 Channel DVD Player with Home...
RCA RT2500 System Logo
380 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
