Question about Garden
My husqvarna yth2448 blade keeps stopping. Can I make simple adjustments, or do I need to change belts, or something else?
  • 218 Answers
Hi..my name is Keith...i would guess the belt is wore out..but you can check this ...but 1st of all...DISCONNECT THE BATTERY AND SPARK PLUG!!!!!....and engage the blade and stick your had under the deck and hold the blade and with the other hand pull on the deck belt..and if it slips easily..then it needs to be replaced..i hope this will help..if not..write me back
Posted on Jun 30, 2009
HUSQVARNA RIDING MOWER BLADES STOPPED SPINNING
Your deck belt adjusted or maybe a spring or etc. come off.
May 13, 2012 | Husqvarna Garden
Ignore previous message - Belt that operates my mower blades popped off. Looking in my manual it appears diagrams for the belt is missing. Anyone have something to help me get this thing back...
I had one, the deck belt routing diagram was not only in the manual, it was also on a little decal attached to the top of the deck. A google search goes a long way, check for AYP and MTD websites as they make about all the mowers, regardless of the label on them.
Jul 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and...
check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
May 29, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a husqvarna riding mower that when i engage the blades the engine stops running
Could be something jamming a blade or belt. With the engine OFF and the key OUT make sure the blades and belts all move freely by hand. Clear out all grass and c**p from the blade and belt areas. You may have to remove the blade deck to do this - instructions are in your manual or download a manual from the Husqvarna website. Good Luck!
Sep 07, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Jul 31, 2009 | Husqvarna Garden
Husqvarna gth main belt keeps breaking
Make sure the mower rake angle is not too much,On level floor point one of the blades in a front rear orientation,measure height of blade from floor the front measurement should be no more than 1/4" lower than the rear measurement.If the front of the mower is too low the angle the belt has to run is too much and the belt will twist and wear rap[idly.To raise the front of the deck there are either one or two adjustment rods that attach the front of mower deck to frame tighten this adjustment up to raise the front of mower deck.
Jul 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna yth2448 riding mower
you probably need to adjust the tension. if you look somwhere near the drive belt then you see a spring. tighten the spring to tighten the belt.
Jun 20, 2009 | Husqvarna Zero Turn Mower Z5426
Garden Logo
243 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
