Question about RCA P46921 46" Rear Projection Television
Big screen RCA
My RCA big screen just shut off and smelled like something burning. I unplugged it and tried again and it will not come on and still smells.
    Genius:
  • 1,694 Answers
Bad flyback ? P46921YX1 = part # 239111.................
P46921YX4 = # 250694..............................T.
Posted on Dec 21, 2007
SOURCE:
Zenith R57W46
Unplug set and do not plug again---something has burned so there is a risk of fire---unless you are familiar with fixing sets consider having a tech come out or take set to a shop for a estimate.
Jun 16, 2012 | Zenith R57W46 57" Rear Projection...
I have a rca d52w23 while i was watching tv in shut off and there was like a smoke smell I mean I turn it on and it shuts off by it self is it worth fixing it and what can cause this problem
Where there is smoke something burned--unplug set for safety and if curious open rear cover and look at boards near rear of set for a burnt part--that will usually determine if worth fixing or not.
Apr 26, 2012 | RCA D52W23 52" HDTV CRT TV
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
My rca 52" rear projection won't stay turned on. It shuts itself off and smells like something burning
Pull back Off and see what is causing burning smell, and CK capacitors on deflection board its the bottom board to the left has FBT flyback transfomer on it 3caps to check are cp150 2200uf 16v use 25v if it is puffed up on top then it is Bad other 2 caps are cp114-cp120 220uf 35v
Nov 14, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
50' rca projection tv
your high voltage splitter is probably bad, or you high voltage flyback transformer (deflection board). not sure of your model #, is it correct? It may be a lamp but you shouldnt smell burning. You can unplug and let it discharge and find where the burnt up parts are to find your problem. Follow your nose, it always knows!
High-voltage can hurt/kill you.. be very careful
Jan 23, 2009 | RCA L50000 50" Rear Projection Television
SAMSUNG HT-X50
Do you smell anything burning. This happened to me and I cut it back on. It stayed on for 30 secs or so and did the same thing. After doing this 2-3 times, I smelled a burning. Being a member of the Fire Dept, I didn't want to see my buddy's coming to the house, so I unplugged it. The next day, I took it apart and there was a burnt resistor or something under neath the fan. I took it back and they gave me a new receiver, but I'm expecting the same with this one.
May 16, 2008 | Samsung HT-X50 System
RCA P46921 46" Rear Projection Television Logo
136 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
