Question about Canon PIXMA iP4300 InkJet Photo Printer
USB002 error message - Open paper tray and it is open.
I have a canon ip4300. Each time I print I get an error message USB002 "document printing cannot be executed becuase the paper output tray is closed. Open the paper output tray. Printing will resume". The paper tray is open but my black ink is out. Does this affect the printing as I dont want to buy more ink if the printer is broken. Thank you Trev
  • 5 Answers
SOURCE: printer door open message
Apparently a solution has already been posted here: http://www.fixya.com/support/t345435-ip4300canon_printer
The author provides instructions on opening the printer and gluing the sensor into the "open" position (assuming that the sensor still works).
Posted on Apr 04, 2008
  • 5 Answers
SOURCE: wont print
I just wanted to add a little note to this issue. I had the same problem, except the tiny lever on the output tray microswitch was broken off, so there was no way for me to lock the switch in position with glue (or tape as suggested above). So instead, I bent the two leads for the switch as close together as possible using needlenose pliers and used a soldering pencil to melt the existing solder and fuse the leads together, effectively closing the circuit permanently. (I could also have just disconnected the two wires from the switch and soldered them together.) I now have a functioning printer.
Posted on Apr 06, 2008
Further to this, the sensors can give way. Try soldering or pushing the two connections together. If you need to test, you will have to put the lid back on but you can leave the sensor out of the rinter by draping between the cover and the frame of the putput tray (be careful not to pinch it. AAMOF I leave my sensor out as even though I've pinched it together it has a habit of coming undone.
Posted on Jul 13, 2008
  • 214 Answers
SOURCE: Cannon ip4300 does not recognize when printer output tray is open
The micro switch on the door may not be working. You need to fix it or replace.
Posted on May 16, 2009
ic0729
  • 212 Answers
SOURCE: canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Posted on Mar 19, 2010
Canon Pixma i4300. Front output paper tray pounced on by pet cat. Closed it up and opened it again When I try to print I get this message: "Document printing cannot be executed because the paper...
If you can remove the tray - have a look at it and it should come out without much force by pressing on the sides. If it comes out you may see the sensor inside that maybe is bent up and is not registering that the tray is open. If you see it you can bend it back down. You can also shoot canned air(with the tray in the out position of removed from the machine) and a piece of debris may come out. Use short squirts or the can gets very cold. All the office supply places and computer stores sell the cans of compressed air.
If none of the above helps, you can always communicate directly with Cannon at:
http://usa.canon.com/cusa/office?pageKeyCode=contactUsLanding
I have found them to be very helpful. Good luck..............................Pete
Jul 20, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Error 1250 on PIXMA ip4300 printer. Despite open tray messae will not o away or allow printing to start.
the error message means there is something wrong with the printer and if the problem is not attended to, the error message will not go away.
In this case, the error message showing on your canon ip4300 is related to a door problem. It has something to do with the front door of your printer. I think the front door of your printer is closed of which is supposed to be opened.
So, the solution is to Open the paper output tray of your printer and the problem should be solved.
Good luck.
May 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Error code while trying to print
Slap the printer with your right hand from the right side of the printer.This process always solves the problem. I did, it worked
Apr 01, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip4300 printer says paper output tray is closed. wont prin
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
We have a Cannon Pixar ip4300 I accidently kicked the paper tray door once when it was open and now everytime we try to use the printer we get an error message about that we need open the paper tray d
I think your on the right track, youv'e probably dislodged or broken a micro switch, screws are mostly underneath, be careful this could turn into a Mecano Nightmare! Good Luck the Yeti
May 20, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Printer door open message
Apr 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
CD printing
there is a small,square button near the right,front corner. think of it as the button for the refrigerator light. It must be depressed by the closed top or maybe something to wedge it down. Duh
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
874 people viewed this question
old marine
old marine
