Question about General Electric DHDSR46EGWW Dryer
Squeaking in GE ds4600 Dryer
Bearings need to be checked and lubed, how do I get in there the best way?
  • 659 Answers
Every unit is different. Some units you have to remove the electronics and the top of the unit first before removing the back panel. Try laying the unit on it's back and see if you can access the unit from the bottom.
Posted on Apr 18, 2009
Dryer was squeaking and now it just clicks when you push the start button
if motor will not run. check it out! it may be seized or in need of oil on end bearings. ( each end of motor ) just get access to the motor.
Feb 01, 2012 | GE Dryers
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
I have a ALE 866 dryer and everytime we run it, it is making a loud squeeking sound
Hello- The squeak is most likely coming from the drum rollers which are located under the drum in the rear; these often become sticky due to the heat and dust inside the dryer. It is usually best to replace them once the machine is opened up though sometimes the bearings are ok and one can just remove the wheels and clean the roller shaft with a green kitchen scrubber. The best lube to use is graphite because it does not break-down and get gummy with the heat generated by the dryer. The drum has to be removed in order to perform the service and Maytag (AMANA) belts are very tricky to put back on so I would suggest having a Tech out to accomplish this. They could also clean the inside of the dryer cabinet of lint and check the belt and other components for wear at the same time. Best regards.
Sep 27, 2010 | Amana ALE866SB Electric Dryer
I have an old GE dryer model DDG5380valwh. When try to start it it just hums. What should I do?
** ALLWAYS unplug a dryer before working on it.
Humming means the motor may not be turning.
The motor could be 'capacitor start'. Replace the capacitor.
The motor could be centrifugal start. Remove the belt. Still won't start? Replace the motor.
The motor bearings could be seized. Rebuild the motor or replace it.
The belt may be broken if the humming is a higher pitch. Replace the belt.
The drum may be jammed. Clean and lube the main bearing (Use Maytag Turbine oil or the recommended lube), the support wheels or the guides. Replace felt seals at the same time for best results.
Mar 22, 2010 | GE DWSR405EBWW Electric Dryer
417.83142201 just replaced felt pads, upper and
try to lube the rollers on the back wall, where the drum mounts , sometimes the wheel bearings tend to make noise specially when dryer is overloaded and hot
Feb 05, 2010 | Kenmore 83142 Electric Dryer
Ge dryer dsks433ebww dryer has slight squeak when running
you will need to remove the front cover and replace the drum glides or rollers,the glides are made of teflon and when they get old they squeak or the bearings on the rollers are made of nylon and do the same
Feb 03, 2010 | Dryers
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
GE electric dryer is squeaking. It seems like it sqeaks loudest when the clothes are wet.
It sounds as though the bearings are going bad. You will need to check if they can be lubed. Most bearings in this type of environment (lint, dirt) are sealed. The reason why it's louder while the clothes are wet is because they are heavier.
Apr 18, 2009 | Dryers
General Electric DHDSR46EGWW Dryer Logo
201 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
