Question about Dishwashers
Currently the only setting that is working is Sani Wash. If I use any of the other settings the Intake Drain light comes on and everythig stops. How can the Sani Wash cycle work fine and no Intake Drain light when all other cycles trigger the Intake Drain light and won't continue to wash? Thanks,Karen
I decided I'd wait for the repairman; I don't want to have to pay additional money.
Posted on Apr 19, 2009
My soap dispenser will not open during the wash cycle
There is a quick test to verify there is a problem, this test will take about 2 mins. Open the door, close the dispenser (latched), on the control panel itself, push in this order hi temp wash (HTW) than sani *3 times in that order*. So that means HTW-Sani, HTW-Sani, HTW-Sani. What this will do is run a control service mode, all the LED's will light up, close the door and wait until it stops, within about 45 seconds you should hear the dispenser open. If it opens it is functioning normally, if not, it should be replaced.
I hope this helps
Jul 29, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Intake/Drain red light comes in and shuts down during wash cycle
I had the same problem. Switched to powder detergent instead of liquid and the problem was solved! Hope it works for you.
Nov 11, 2007 | Dishwashers
You will more that likely have a faulty waterproof inlet system
May 17, 2007 | Miele 24 in. Novotronic G851SC Plus...
Open Questions:
Dishwashers Logo
386 people viewed this question
Top Dishwashers Experts
Owen Barnes
