Question about Kitchen Ranges
Vollrath induction cooker is not working. The display reads F9. Model # is 59500.
Induction cooker from Vollrath is not working. The display reads F-9. Model #is 59500.
The range does not recognize the pan material. Only ferrous (magnetic) cookware will work with induction. This is a protection circuit to only heat proper cookware. When all else fails read the instruction book or call the service department for the manufacturer...save time, reduces frustration and assures safe operation. Good Luck
Posted on Nov 19, 2009
No matter what pot we use, it wont work
Most cookware found found in home today is aluminum or cast aluminum. These do not work on induction cook tops. Even older stainless steel Farberware doesn't work because it is not magnetic. Look for an induction compatible label or stamp on the cookware to be sure.
Induction cookware must be made of a magnetic-based material, such as cast iron or magnetic stainless steel. Fully clad cookware brands, such as All-Clad Stainless, Le Creuset Stainless Steel and Mauviel M'cooks stainless work on induction cooktops because they're magnetic.
Mar 15, 2015 | Eurodib Induction Cooker
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
When have weight on induction cooker cooker can not cook
Remember that induction cookers are fussy that you have a special stainless steel pot or pan made just for induction cooking. It must be an 18/10 alloy (18% chromium and 10% nickel)
Oct 02, 2013 | Winco Professional Induction Cooker -...
INDUCTION STOVE
I have Bajaj Induction Cooker MAJESTY ICX 2 model. While it is working suddenly the display shows E4 and heating stopped. the on/off switch also not functioning. Pl. tell me how I will repair the cooker and what spares are required for repairing.
Thank you,
Susanta Banerjee
banerjeesusanta8@gmail.com
May 27, 2013 | Max Burton 6015 Portable Induction Cooktop...
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
I have a prestige Induction cooker... a new one. When I tried to turn it on for first time, it just shows "-- -- -- --". Post this, even after placing a induction cooker compatible vessel, it...
We have a Prestige Induction cook-top Model PIC 3.0. It gives the error "-- -- -- --" and a beep when the power is turned on. Can anybody help. My email is asbhambra@gmail.com
Mar 11, 2011 | Microwave Ovens
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Kitchen Ranges Logo
861 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
